Question about Zenith C27A24T 27" TV
How do i bring up the menu?
How do i go to menu so that i can adjust tint and color?
  • 1,297 Answers
Open the main menu-move to picture menu-acces picture menu-move to your choice-increase or decrease levels-press the exit button.For return the factory setting press the N button.
Posted on Sep 07, 2009
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
I have the Insignia Dual 7" Portable DVD Player. Model NS-7DPDVD. I'm noticing a yellowish color on the movies. I adjusted the brightness wheels on both but it's not the brightness it's...
Bring up a menu on the DVD player screen (not a DVD menu, the dvd players settings menu). Is this menu also tinted yellow? It probably is, and you probably have a faulty part internally.
Jun 13, 2011 | Insignia Dual 7" 16:9 Widescreen LCD...
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
Jan 03, 2011 | Televison & Video
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
RED TINT OVERPOWERS COLOR
You're probably missing one of the other colors, green most likely or blue.
There are adjustments that can be made to bring things back into balance but you need to know what you're doing.
First, I'd have a look and make sure all your tubes are working correctly.
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
Zenith C27A24T 27" TV Logo
163 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
