Nothing works on drivers door, no power windows, no door locks, no power mirrors, no trunk lid, no gas lid, but the other doors work fine and all power windows work fine with local switch.
I left driver side door open for hours, I hit the door lock on the remote and it beeped wich meant all doors were closed even though the drivers door was opened, I got in closed the door and went for a short drive, first the instrument panel said the door was open even though it wasn't then it wouldn't lock with the remote so I manually locked it with key in door and left it till the next day.
The next day I noticed the door light was out but the bulb was good. Now the door is completely dead. I tried disconnecting the battery for about 10 minutes but there was no change. also checked all fuses, they were all good.
Is there a plug or some kind of fuse inside the door? If anyone can help it would be apreciated thanks.
I just fix the same problem :(
Two wires in harness were broke. Let me give you some instructions to fix this. 1- Remove the inside panel. then remove the conection that is in the middle betwen the door and the body of the car, is like black cover for the wires. In my case 2 of these wires were broke.
2- Remove the screws of the door in the frame then close the door and pull the door only a few inches just to have acces of your hand to pull the wires.
3- Add another piece of cable, to meke these cables longer, and put everything back.
call 21-642-9775.
2006 jetta has a known problem with the drivers door harness being too short in the a pillar. recommend new harness.
where is the switch assembly
jetta 2006 tdi driver side window stopped working,every thing else is working.The switch engages but the window doesn't open ,switch has power.
