Motor turns on, brush is revolving, suction working, but no steam or spray solution is coming out.
Try the following steps -
- Make sure there is water/formula in the solution tank and check to see if water comes through the cap insert by pushing up on the “X” valve on the insert. If not, clean the cap insert with a soft bristled brush and hot water.
- Check to ensure the red or black gasket on the cap insert is attached to the cap and not lodged in the reservoir of the machine. The gasket is a soft rubber material. Without this gasket attached, the tank does not seat properly.
If the tank releases manually when the "X" valve is depressed and the gasket is attached:
- Remove upholstery tool and depress trigger for 30 seconds with unit turned off. Turn the machine back on, depress the trigger, and lift solution tank up and down. This will prime the machine.
- If the machine sprays with the tool detached, gently clean the spray tip on the tool using a paper clip.
- If there is still no spray, try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
Good Luck!!
Thanks
