Question about BenQ PB7210 Multimedia Projector
How do i fix the fans that don't work, and cause it to overheat?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Depending on the problem with the individual fan--either it physically is not turning or it's not putting out a computer signal. Red is positive, black is negative(ground), and yellow is for the computer pulse--it tells the main board that the fan is turning. I've never been totally successful in repairing a fan for a projector. If it died due to heat expansion, (i.e, the motor binds and stops) you can't repair it. Sometimes, if the computer signal is gone, you can open up the motor and replace a bad component--remember, those fans operate in a HOT environment--better to try to find a replacement on the net. Look up Rotron (big manufacturer) and some laptop repair places--they can sometimes point you to sources of different size fans. I've found that in most cases, the fans were manufactured specifically for the projector company and you'll have to find one that is close enough in size and modify it to fit.---Rick
Posted on Sep 07, 2009
What would cause car to overheat if it has engine coolant in radiator and reserve tank, radiator fan may not be working
If the fan doesn't come on when the temperature goes up, and it should, that's the reason it's overheating. Fix the fan or fan switch.
Sep 08, 2014 | Cars & Trucks
Eee 1015PE is overheating and shutting down
Is the fan working? You will need to replace your fan if it's not functioning. And don't use it in that condition, you risk damaging it everytime it overheats
Nov 17, 2012 | ASUS Eee 1015PEM-PU17 Netbook
1994mitsubishispacewagon still overheats after replacing auxilliary fan sensor, cleaned the hoses, pls help
Thermostat stuck take it out. leave it out .. try it ...then
put in a new one...or water pump weak. Also try wiring the auxiliary fan and any other fans so that anytime the vehicles motor is ON the fans are ON don't depend on a sensor on a Mitsubishi of that age...fans that don't come on soon enough, or stay on long enough, or turn on at all without letting you know until the motor overheats..... , are the leading cause of death for vehicles~!! lol
Jun 22, 2012 | 1994 Mitsubishi Expo
1999 mazda 626 cause overheat ???
I would look at the owners manual and make sure that it calls for a 40 amp fuse. Maybe it's not the right size. But you don't want to go too big because if it is shorting out in the wiring it could cause a fire. Make sure you have the right size fuse if not, there is a short in the wiring or in the fan motor itself.
Jun 11, 2012 | 1999 Mazda Protege
Overheating of graphics card while playing games
  • Clogged fan
The main device responsible for maintaining a constant temperature of your video card is the fan present in the processor. If this isn't functioning efficiently it's quite obvious that it would result in your video card overheating. If you don't regularly clean your computer, it could be highly likely that your fan is clogged with dust.
This is one of the simplest causes of your video card overheating which can be fixed by simply cleaning your fan, preferably using a blower.
  • Broken fan
A follow up of the previous point, in some cases your fan maybe malfunctioning or stopped working altogether. This could simply be diagnosed by switching on your computer with its cover open and checking if the fan is functioning. If it doesn't happen to be working, you have your answer.
  • Overclocking
Pushing your CPU to its limits by overclocking can cause your video card to overheat. This can seem fairly obvious too as if you find your video card overheating and if you've recently overclocked your CPU, it would explain it.
  • Faulty Drivers
This is a rare cause, but depending on your video card's brand a badly developed driver could also cause your video card to overheat. If you use an unusual video card with questionable reputation this could be the issue.
  • Inefficient Airflow
While your fan maybe perfectly in tact and working, the location of your fan also matters. If there isn't sufficient air flow to your video card it can also cause it to overheat.
Those are typically the 5 main reasons to your video card overheating. If you have any other points in your mind, feel free to share them below.
May 09, 2012 | ASUS GeForce GT240 1G DDR3 550Mhz
Replaced thermastat but still overheating
OK, you have addressed the first possibility. There are a few more, each progressively more expensive to fix. First, are the radiator electric cooling fans operating? If you find the vehicle runs ok on the highway, but overheats around town in stop-and-go traffic, it could be that the fans are not running. Quick check for the fans - with the ignition on (the engine doesn't need to be running), move the cooling control to the A/C position. If the fans come on, they are good, but you could still have a fan-related cooling problem. If the fans don't work, you have a problem. If the fans worked, the car runs fine at highway speed but not in town, then suspect the coolant sensor that engages the fans. If the fans work and the car overheats in all conditions, then a system blockage is possible. Blockages occur usually one of two ways: Radiator rust/corrosion, and collapsed radiator hoses. Radiator corrosion will require radiator replacement; if it is blocked badly enough to overheat, flushing it is a waste of effort, and could cause more problems with all the **** you circulate into the engine. If the system is low on water (air in system) it can rise to the top radiator hose and cause it to collapse partially or fully, restricting flow. Some engines have water jackets that extend higher than the radiator cap, so they can trap air. These cars have bleeder ports at these locations to remove to trapped air. Check to see if that is the problem.
Dec 17, 2011 | 2001 Chevrolet Lumina
Will a faulty thermostat stall my 2001 montero? its temp gets high but i know i have water on it. or would a faulty aux fan be the cause? please help. i dont think i blew up the head gasket.....YET. oil...
no , a faulty thermostat will not cause the engine to stall as such, but if the aux. fan is not working it will cause the engine to overheat if idling for long period, you don't need the fan to be working if you are traveling more than 40-50 MPH.....cheers .....hope this helps
Jun 07, 2011 | 2001 Mitsubishi Montero
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
Overheating receiver
I opened my receiver up and found the fan not working. So I took the front of the unit off so that I could access the fan. It looked brand new so I don't think it ever worked. I checked the fan connection with a volt meter and found 12 v only the fan still would not run. I took the red wire coming from the fan and put it to ground. Cut the yellow wire off the fan. and the black wire to the middle of the connector on board. there the fan worked. now I have a working fan. maybe this could be your fix just don't lose the screws and remember how this comes apart. I know the fan works not so sure it fixes problem but at least the fan is working so thats a start. At least it won't overheat. hope this helps
May 31, 2008 | Audio Players & Recorders
BenQ PB7210 Multimedia Projector Logo
199 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
