Question about Visonic Computers & Internet
Alarm in memory, will not allow me to arm
The system reports 2 zones as being in error, the master bedroom and garage. I have never used these zones and so do not know where or why they are being reported as in error. The problem is that I cannot arm the system because the unit believes these zones to be in error.
I have done a factory reset but the problem persists... any ideas?
Thanks
Jason
Bubbabear64
  • 2794 Answers
SOURCE: Recovery Disk can not recover system
It could be a hard drive crash. Can you refort the hard drive and see if you get any errors.
Check to see if you have any scratched on the CD.
Posted on Jun 22, 2008
SOURCE: Master Software 2 help!
Ditto. Installing on XP w/SP1. Plenty of hard drive space. Pentium 4 w/2GB RAM. Tried different drives. Tried copying CD-ROM to hard drive to verify it was reading of the CD ok. No problem copying but still failing on installation. I also tried by-passing the initial Olympus menu and launching the .msi directly, but that fails in the same way. I haven't found anything on the Olympus website about this, but note their website generates tons of Javascript errors which is not encouraging with respect to Olympus's attention to quality. (This is my first and probably last Olympus.)
Tried pulling the XD media and reading it on the computer but my computer wanted to format the thing (never seen that with SD or Compact Flash, what gives?) so that was a no for the moment.
Finally, I went to the files that I had copied from the CD to my hard drive and double-clicked the OM2_Pack_Framework_2_0_4.cab file found in the OLYMPUS\OLYMPUS Master 2 directory. That contains a bunch of .cab files, that I extracted to another directory. In there, I found a application.cab, which I then extracted to yet another directory. In there, I found OLYMPUS Master.exe. That ran fine when I double clicked on it, but I still had the problem of not being able to read the XD directly, so I hooked the USB up to the camera with the XD back in the camera and was able to transfer the images in that manner.
Posted on Jun 28, 2008
jrod1125420
  • 161 Answers
SOURCE: Canon MX310 Printer - How to reset to factory settings?
usually there is a menu in the printer itself. does it have its own little screen? if so go to tools or setup n look around to find default or reset n hit ok.....lemme know what happens
Posted on Sep 30, 2008
ninexunix
  • 64 Answers
SOURCE: Crystal reports version 8.5
I'm not an expert in Crystal Reports, however you might find my info and experiences to be of some use with your question. I've been working with VB6.0 for some time. One day I decided to checkout Visual Studio 2008, (which came with crystal reports) I decided I didn't like it and removed it from my computer. It was after the removal of crystal reports that my computer went to hell. Every program I tried to install since it's removal was not being allowed, also every program I tried to uninstall was not being allowed. After some research I found out that Crystal Reports was the culprit. It has a management package that was designed to protect it's rights management. Simply stated.....it was governing parts of my registry by setting certain parts of my registry key permissions to, "read only". I ended up having to use the administrative tool in Windows XP and reloading default permissions through an existing INF file thus resetting every registry key back to it's default read/write state. I would not recommend you do this. Doing so may harm your existing install of Crystal Reports. What I would do though if I was in your situation, would be to change just the one key that pertains to your .tmp file location in regedit. My guess is it would be located HKLM under software. You can change any key permissions by simply right clicking any key and go to, "permissions" However, if i'm guessing right, Crystal Reports has a backup mech. that would not allow you to change the key permissions even in regedit. In wich case you'll have to use a utility like ::.HERE.:: and create a custom bat file for just that one key. You can try contacting Crystal Reports directly but i'm quite sure they'll just tell you to kindly, "get bent" lol. This method of protection serves no purpose other then to protect their software from being pirated. So i'm 99% sure they won't help you in the matter that you need. Changing permissions to registry keys back to default would negate their program protective measures. From the problem you described i'm 90% sure that is exactly what is going on due to what I already know about the protection measures of Crystal Reports. Any file that is being generated with Crystal Reports, temp or otherwise is now governed by Crystal Reports through your registry, through a registry like firewall, also run by Crystal Reports. This is why you're getting Access Denied when you try to right click the file and delete it locally. You have two options.
1.) Become submissive and a slave to their tech support and wait for them to come up with a solution that will allow them to maintain control over your registry, with a patch of some sort provided by either Microsft Visual Studio or through Crystal Reports directly that will resolve your particular issue.
2.) Setup a dummy computer install all the crystal reports programs on it. Get it all setup, then do a full registry reset (from that link i posted above) and see if you can still use crystal reports after the full registry reset and if that truely resolves all the access conflicts. If so then apply it your main work machine and once again become the master of your registry.
Hope that helps,
9x
Posted on Oct 09, 2008
SOURCE: master reset W700i
go to setting and look for master reset,press reset all,and the default password is "0000"
Posted on Nov 30, 2008
Help! Home security alarm FC-300 Plus keeps going off??
Check memory and see if a zone was in alarm.
If zone was in alarm it can be.that it is a 24hr zone or the panel could be programed to ARM on no movement or ARM on time. Needd more info to help you more.
Apr 27, 2017 | Home Security
New apartment with A honeywell ademco 4110xm. I connected power and got master code. I get CHECK 05 and ALARM 06. Typing the code and OFF disables the ALARM 06 error, but Check 05 remains. Any help?
It is telling you that a zone is not working properly or is open. Ex. door not shut, window not shut. Something moving in front of a motion sensor. Fin out what zone 5 is and that is your problem for arming. Could be a battery if this is a wireless system.
Jan 18, 2016 | Honeywell Home Security
Why does a 5816 door sensor in my Lynx 5200 system send a fault message even when system is disarmed?
Jon, I am not 100% sure what you are asking about. However, is the keypad shows 'Ready to Arm' when the door is closed and then shows the front door in fault when you open it, then that is how it is supposed to work. When the system sees a door open or movement, then it shows on the zone in fault on the leypad. If you were to try and set the alarm with the door open, the system can tell you which zone needs to be corrected before you can set it. Usually it is as simple as closing a door or window. When the door is closed and it says that it is ready to arm, you are good to set and leave. Opening the door with the alarm off or on will report on the keypad.
Dec 29, 2014 | Honeywell 5816WMWH, Wireless Door/Window...
The fire alarm in the master bedroom is beeping for every 5 seconds.. wat to do
Sounds to me like your 9 volt battery is dead. I just went through the same thing and I put new 9 volt battery in it. Problem solved.
Oct 15, 2012 | Home Security
How do I set my alarm, I have the code for it but no instruction manual
You can just enter the code on the keypad and the system will arm in 'away' mode, meaning it will arm all zones and it will expect there to be no one in the home or business The keypad should beep and show that the system is arming up. If it does not, then you didn't enter a valid user code and you will need to contact your alarm installing company to provide you with a valid user code, but also it appears, some information on the use of the system.
Mar 06, 2011 | DSC Pc9155cp01 Alexor Wiress Alarm Panel...
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows an alarm memory stating ''panel lid''. How do i reset this alarm message?
An "alarm Memory" indicates that a zone was activated the last time the system was armed. To view what zone caused the problem press the * key (star) + the 3 key. To reset the memory simply arm the system and disarm. Hope this helps.
Apr 21, 2010 | DSC Power Supervision Relay For Smoke And...
How do i change the panel voice feedback on GE Simon 3 to say something different? For instance, instead of it saying "East Bedroom Window Open", can I change it to say "Blue Room Window Open"? I have 5...
Unfortunately the Simon 3 has a limited vocabulary. The alarm company probably did the best they could. It will tell you the zone number 1-24 but you may already have the best audio descritption you are going to get.
AlarmProfessor.net
Apr 07, 2010 | GE Security Simon 3 Wireless Home Security...
Alarm goes off went armed as well as strobe won't go into armed mode
Smoke sensors will trip if dust accumulates in them. Get a can of compressed air like they sell for cleaning the vents in computers and try blowing the dust out. That should reset your sensors, If not you could disable the fire sensors for your trip and get it serviced when you return.
May 29, 2009 | GE Security Simon 3 Wireless Home Security...
Hello sir, the system zone-2 temp., always keeps flashing in red.
It is a motherboard problem. But you can disable that alarm from the BIOS. I would simply raise the upper threshold in zone two from 56 to 60 if I were you. If it still flashes red put it back to 56 and disable it.
Apr 26, 2009 | Intel D865GBF Motherboard
Ademco Alarm System - Zone works opposite? Triggers on (door closed)/ Stay Off (door opened)?
i dont think it polarity not unless alarms in the usa are different from nz aus uk sounds like you have a faulty something. try open and closing the front door and look at the keypad to see if the zone activates as it should. there can only realy be 3 things. device, cable or panel fault. you can easly test the system by swaping the zones in the panel ie zone 1 to 2 and 2 to 1 providing that they have similar zone charectorists ie "entry exit" if the fault moves to the other zone you know its a device fault.(inspecting the cable for damage is probably the easy thing to do) if its a reed switch you could look at the position of the magnet it may be making borderline contact and a slight movement of the door could be tripping the zone. if the fault doesnt move its a panel fault. before you jump in though make sure that if you dont comprimise your protection or insurance by trying DIY security. good luck (if you have no joy post more details)
Dec 14, 2007 | Eagle SeaChamp 1000c Recording Sonar...
Computers & Internet Logo
55 people viewed this question
Top Visonic Computers & Internet Experts
David Payne
David Payne
Are you a Visonic Computer and Internet Expert? Answer questions, earn points and help others
