Question about Bosch Nexxt WTMC3321US Electric Dryer
Bosch nexxt 100 series electric dryer wont heat up to dry clothes
Not even 4 years old. the dryer coil that runs to the outside exhaust came off, so i tilted the dryer forward and put it back on.. set the dryer down and then turned it back on and realized it was not heating up?? what can i do to start diagnosing the problem..?? im upset it happened after not even 4 years
5 Suggested Answers
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Nexxt 500 series dryer. Today I was
Hello, Welcome to FixYa. There are a couple of scenarios which may prevent the dryer from starting with Bosch, but based on your post it is most likely the emergency shut off/belt switch. It is located by the motor and in the event of too heavy a load or a broken belt it shuts the unit down & prevents any restart...until it is repaired or reset. To save time and back and forth dialog, I`ll mention what to do about it. **Unplug the dryer before attempting any repair tips suggested here please...safety first** This will require you to remove the back panel. Once you've remove the rear panel, It is located next to the belt pulley and all you need to do is push it to the right ( from the back ) Let me know if you require further assistance to do this. Keep me posted how you make out or if anything is not clear. I'm presently on my iphone, but I can post more info with pictures to guide you if necessary...but please let me know. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
Posted on Dec 21, 2010
sonicboomele
  • 1557 Answers
SOURCE: my mom's bosch nexxt dryer
in 99% of the case if the unit is running correctly but not heating the heat element is blown and will require replacement.
have a great day
sonic boom electronics australia
Posted on Jan 04, 2011
My Whirlpool Duet DRYER--the clothes are wetter than when I put them in & there is now water sitting in the bottom. It does have a steam setting, but I'm not using that one. It's 4 years old.
Check your exhaust vent! If you have an obstruction, the steamy air will have no where to go, then your air-conditioning temps inside can cause the water to condense in the vent tube... Even if the vent is just open to the hot summer air and the clothes sit in the machine the difference in temps between inside and outside can cause these symptoms...
Jul 25, 2016 | Whirlpool Duet High Efficiency Gas Dryer...
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
My dryer will not dry effectively, it is very slow to dry even on the high heat settings, any ideas?
i looked up your model number and you have a gas dryer not electric,if the vent line is clear and the metal duct that the lint filter slides into is clean i would say you have bad gas coils located on top of the gas valve,when the coils go bad they will work correctly for the first 15 to 30 minutes,when they heat up they fail and the flame won't ignite,so do this remove the screws that hold the bottom panel on,remove the panel and vac out any lint you see,if you have a shop vac you can set the vac up to blow and blow off the motor and blow all the lint forwards and vac it up,do this with the dryer unplugged,remove the lint filter and take out the screws that hold the metal duct in place and clean the duct out,put it back together except for the screws that hold the bottom panel in place but just stick the panel in place,put some clothes in and start the dryer,after around 20 or 30 minutes remove the bottom panel so you can see the ignitor,if the ignitor glows orange but the flame doesn't ignite and the ignitor goes out then you have bad gas coils.you should take the bottom panel off and remove the lint filter duct and blow and vac it out once a year,also if you vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure nothing is blocking the outside vent like a cage or a piece of screen so the lint can blow out and not get blocked.the part number for the coils is 279834 and they are around 25 dollars,unplug the dryer,remove the bottom panel,remove the two phillips head screws,remove the cover,slide the coil up and off of the post,unplug the wire and connect it to the new coil,watch out on the big coil,there's a spacer that has to stay on the post,sometimes it gets stuck in the old coil when you remove it,let me know how you make out.
Mar 19, 2013 | Kenmore Elite HE4 Electric Dryer
My Amana DLG330RAW igniter glows orange and a flame is produced initally when starting the dryer but after the flame goes out when the igniter glows orange again (shorter glow time) a flame never occurs...
could have bad gas coils? part 279834 they're located on the top of the gas valve unplug dryer,remove the two pillips screws,lift up the cover and change out the coils,watch out on the three prong coil there's a spacer that you want to stay on the post so when you slide the new coil on the coil it's tight,if the spacer isn't on the post after you remove the old coil look in the old coil and stick anything that will fit and push out the spacer then slide it back on post then install your new coils.also while you're in there get a shop vac and vac up all the lint you see,remove the lint filter and then remove the duct that the filter slides down into and clean that,then set the vac up to blow and blow all the lint from the back forwards and vac that up,make sure you blow the motor off and the gas tube and parts,you should do this at least once a year with gas so you don't have a fire,then go outside and make sure the duct is clear no cages or anything on it,go back inside and remove the vent line from the back of dryer,if it's a long run you can stick a leaf blower into the vent line and blow it out.if you need anymore help let me know.
Oct 12, 2011 | Amana DLG330RAW Gas Dryer
Bosch nexxt 500 series dryer producing intermittent gas smell when running. wife says the smell has even permeated the clothes a time or two, but I haven't noticed it. heat exchage box? if so, how hard...
A few things to check...
First, check that the dryer vent is not clogged. You'll have to go outside to check. If you are not sure of a clog, disconnect from inside and have your wife hold a flashlight by the vent, then go outside to see if you can see it. This will also cause laundry to dry slower than it used to (your wife may have a feeling if this is the case).
Second, make sure you don't have negative pressure in the house (large house fans are good for cooling but move too much air out so the dryer cannot vent its exhaust gasses well). You can check by opening an exterior door about an inch and check if it swings open with a gush of wind. Even houses without whole-house fans can do this if you have enough bathroom fans and furnace fans going.
Third, If it is a smell of natural gas, then you should call a service technician because the valve is not opening/closing correctly (or fast enough) if you have a pilot-less starter.
May 05, 2011 | Bosch Nexxt 500 Dryer
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Lint is building up in the dryer vent outside and the dryer is heating up but not drying the clothes
you will need to clean out or replace the vent line as you clothes will not dry if there is a restriction in the line.
Oct 04, 2010 | Bosch Nexxt WTMC 6300 Electric Dryer
The dryer doesn't heat up and dry the clothes. I checked the troubleshooting section and then cleaned the lint filter, which we do after every time we take dry clothes out, and then I made sure the exhaust...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 28, 2010 | Bosch Nexxt 500 Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
85 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
