Question about Honda Pressure Washer PSI 3000
I have a Honda 3500 pressure washer. The motor
I have a Honda 3500 pressure washer. The motor starts fine. When I pull the trigger, water comes out under pressure, but the engin stalls. I think it's the oil pressure. Any ideas?
  • 615 Answers
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
Testimonial: "The problem was the governor spring. Thanks"
  • 174 Answers
If the oil level is OK and no leaks it should be OK there
It may be the idle is too low or it may just be a blockage in the nozzle
Posted on Sep 17, 2009
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Jun 15, 2010 | Honda Pressure Washer PSI 3000
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Honda Pressure Washer PSI 3000 Logo
486 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
