Question about Quasar Televison & Video
How do you setup VHQ-450 to audio/video input
How do you setup VHQ-450 to accept audio/video input from audio/video ports instead of ANT IN?
    Habit-Forming:
  • 108 Answers
Press input on remote until display says "Line" or channel down past1 or lowest channel and the next one down should say "Line" that will be the line in. This website has an owners manual that can be down loaded
http://www.retrevo.com/samples/Panasonic-VCR-manuals.html .
Posted on Sep 07, 2009
Testimonial: "Excellent timely answer. What I forgot to say was I inherited the VCR but no remote came with it. :("
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
Having trouble hooking up vcr
I've never seen a VCR use anything other than Composite, S-video or RF analog outputs. That's because VHS uses the NTSC or PAL analog video standards. (In the US, it is NTSC; in Europe PAL is the old standard.)
To use the Composite output, get a triple RCA cable (red, white and yellow connectors). Connect one end of the cable to Video Out (yellow), Audio Out right (red) and Audio Out (white) on the VCR. The other end of the cable goes to the corresponding Composite Video In jack and the adjacent Audio In jacks on the TV. If you are using S-video, (both units must have S-video jacks), the S-video cable replaces the Composite section of the triple cable, so you only need an audio patch cable (two RCA plugs on each end). Be sure to use the audio input corresponding to the S-video input. Note: S-video is generally better quality than composite, although HD digital is still superior.
If you wish to record from the TV, the TV must have a composite video or S-video output. This is not very common. If you wish to record programs from an RF source (cable or antenna), see the next paragraph.
In the days before digital, a typical connection scheme was to run the cable or antenna RF source to the ANT IN coax connector on the VCR, then run a short coax cable from ANT OUT to ANT IN on the back of the TV. This may not work with a digital source. Pre-HD VCR tuners would not be HD compatible, and may even filter out the digital signal in bypass mode (VCR off). You would need an HD to analog converter box at the VCR input to retain this setup. I have no information on your TV's support for NTSC video through the tuner (especially since you did not mention the model : /).
Jun 21, 2011 | LG Televison & Video
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
I found a SuperNintendo that has been in our attic for many years, however when I conect it upo my TV cannot find the output from the SuperNintendo when it does a search. What frequency or channel does it...
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips. Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
Nov 27, 2010 | Nintendo Super NES Console
Can the a15 be configured to accept stereo input?
There are usb audio devices out there that would help you here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815144028
I'm not 100% sure that is exactly what you are looking for but it's a good place to start.
What you are looking for is a video and audio capture device that is USB compliant.
Jul 31, 2009 | Computers & Internet
I just hooked up my wii to my Denon AVR-2307CI receiver and have video but no audio. I set component in assignment to VCR-1 and put Green/Blue/Red in comp 1 and Red/White in VCR-1 in Audio IN
Most likely the VCR1 input in the Denon is set to a digital input, you will need to go into the setup for the VCR1 input and make sure that NONE is selected for the digital audio input.  Also - make sure you did not plug the Red/White audio cables from the Wii, in to the VCR OUT, instead of IN.
Mar 10, 2009 | Denon AVR-2307Ci Receiver
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Vcr taping using rca
Connect the VCR's audio/video outputs to the TV's audio/video inputs. These are the red,white,yellow connectors. get the same colored type cables and it is real easy. Switch the TV to the corresponding input selection. Of course, the signal source needs to be connected to the VCR's input
Dec 30, 2007 | Televison & Video
Televison & Video Logo
155 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
