Question about Air Tools & Compressors
My compressor tries to start when i turn it on but the breaker flips. I just cant get going.
    President:
  • 1,714 Answers
The start capacitor is gone bad. (under the cover on motor) Change it. Take it out and go to a motor repair shop for a new one . OR order it from grainger.com
Posted on Sep 07, 2009
Have a Porter Cable 175 PSI, 25 gallon upright compressor. When you flip the switch, the motor buzzes, but does not start the compressor. The cylinders are free when hand turning. After a couple of...
On these larger compressors, the motor that turns the compressor,
will have one or two capacitors, the capacitor in conjunction with the
motor gives the compressor that extra push or torque that is required
to get it going. if the capacitor goes out, the compressor will not work,
the motor may work but will not have the strength to turn over the compressor..
depending on the size motor, it may be mounted on top, on the side or
even in a juntion box attached to the compressor, if you have to replace one
i recommend powering down or unplugging compressor and handle the
capacitor carefully, use insulated tools or gloves, a capacitor is like a battery
it will hold a charge, but like a battery it can be discharged, the only difference
with a battery and a capacitor, on a capacitor you can have thousands of volts.
it can be replaced just handle it safely, good luck!
Jul 12, 2011 | Porter Cable C6110 150 PSI 25 Gal OilFree...
Why is it my air compressor won't start after power fail until i shut the pressure switch off and turn back on
Hi my name is John. Welcome to FixYa. It will happen when you have a power surge, just flip the breaker in the breaker panel and it should be OK. Thanks for choosing FixYa....John
Nov 11, 2010 | Campbell Hausfeld 26 - Gallon Air...
6hp, 25 gallon compressor, never cycled back on, blew the breaker. reset the breaker and soon as i flip the compressor it trys to start then blows the breaker right away.
sounds like its the motor drawing too much current,has it got plenty or oil cause they run low and seize up,not the most reliable can be fine but equally can be dramas especially if its from China
Oct 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Sub zero 700tc/fan runs but no compressor
A check of your breaker is in order. From your description the breaker could be week. If so the breaker my not cut off all the way and still allow enough power through to opperate the fan but not the added load of the compressor.
I have seen this a few times and it always confuses me too. Check the circuit by maybe moving the circuit on the breaker to a different one then retry it and see if the problem is gone. If it is then replace the breaker if not then its time to use a volt meter or call a repair person. And this is because there are a lot of what ifs that have to be covered to get to the root of the problem if this is not the trouble..
Please lket me know whow this works out. Rate me as high as you can and thank you for using fixya.
Apr 28, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Compressor does not turn on
Go outside and check power at the disconnect switch.
Apr 26, 2009 | Heating & Cooling
Air compressor flips breaker before it will start?
Air compressors tend to draw more power as they age, however, will not trip breaker unless some malfunction. Here are some simple tests. Unplug compressor and turn the pump by hand, you may have to remove a cover to do this. It should turn freely; any resistance could be failing bearing (would make noise) unloader/check valve leaking allowing back pressure to pump, or failed start capacitor/start winding. Easy test for checkvalve. With pressure in tank loosen discharge hose at tank and check for air leak. Check valve should hold pressure in tank. Replace as needed. Failed capacitor/s will cause high amp draw. Remove from circuit and test. UF reading should be within 95% of printed rating. Finally, most air compressor motors have two windings, start and run. Power to windings is controlled by flyball switch inside rear of motor. This switch has contacts that can stick in start position and cause high amp draw. Examine windings for signs of overheating. Copper windings generally have color of new penny. Very dark brown windings bad news. Gook luck
Jan 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
