Question about Dishwashers
My Maytag MDBH965AWW Legacy Series 300 is making a loud grinding noise. I took off the lower spray arm and other parts below it to see if something was lodged near the chopper blade. What I found was broken plastic pieces from the bottom of the filter/flowplate assembly. It appears that the chopper blade is coming in contact with the filter/flowplate assembly and therefore the chopper blade is chopping away at the bottom of the filter/flowplate assembly. What do you think the problem is? How can I fix this? Somehow the chopper blade is coming in contact with filter/flowpalate assembly. Please help. Thank you.
  • 2 more comments
  • cargento1 Sep 07, 2009
    Chopper has Become UNSEATED By Way of FASTENER or BEARINGS
    The dishwasher is only three years old with extremely light use (twice per month) in a secondary kitchen. I actually recently removed the dishwasher from the kitchen as I had new counter tops installed. When I reinstalled it the grinding problem began. I never had this problem before. Could it have been caused by the removal/reinstallation? I am running the dishwasher right now as we speak and there is no more grinding noise. Please let me know how I can fix this problem. Where is the fastener located (inside or bottom of dishwasher)? Thanks.
    My Maytag MDBH965AWW Legacy Series 300 Dishwasher is making a loud grinding noise. I took off the lower spray arm and other parts below it to see if there was something lodged near the chopper blade. What I found was broken plastic pieces from the bottom of the filter/flowplate assembly. It appears that the chopper blade was coming in contact with the filter/flowplate assembly and therefore the chopper blade was chopping away at the bottom of the filter/flowplate assembly. The dishwasher is only three years old with extremely light use (twice per month) in a secondary kitchen. I actually recently removed the dishwasher from the kitchen as I had new counter tops installed. When I reinstalled the dishwasher the grinding problem began. I never had this problem before. Could it have been caused by the removal/reinstallation? What do you think the problem is? How can I fix this?
    I just reassembled the dishwasher and I am running it right now as we speak and there is no more grinding noise but I would like to know what I can do to stop this problem from occurring in the future. Another expert thought the chopper blade became unfastened or had bad bearings but it appeared to be screwed on tightly and did not move when I pulled on it. Please let me know what you think caused this problem and how I can permanently fix the problem? Thanks.
    Thank you. I will consider your solution if needed in the future. After I cleaned out the broken plastic pieces from the bottom of the filter/flowplate assembly and reassembled the dishwasher I ran it through a few cycles and no more grinding noise. Perhaps there was something lodged near the chopper blade at some point which caused the chopper blade to hit the object and cause the filter/flowplate assembly to become chopped up. I am keeping my fingers crossed right now and hoping the problem will not return. We shall see. Thanks again.
    Thank you for all of your assistance.
    President:
  • Dishwashers Master
  • 1,714 Answers
Here is the break down view of what you have. The only way to fix this is to get to the chopper and tighten things up. Look at the photos and you can see the chopper and how to do it, it's a bit of a job...
Remove Chopper Sleeve by using Impeller as a
wrench. Lock motor rotation using the access hole
provided in back of motor.
Here are some illustrations.....
Posted on Sep 07, 2009
  • Craig Butler
    Craig Butler Sep 07, 2009
    Yes, very possible, I have the service manual. Let me know if I can help you. Thanks!
  • 1,596 Answers
Maytag Legacy series dryer making loud noise. Sounds like something flapping.
A common problem on these dryers is the blower wheel itself will wobble out and make noises. Pop the top with a putty knife then remove the front panel. Check the blower housing for looseness.or something in it. I worked on a monkey wards dryer with a bad blower wheel and made crappy movie on my phone:
Sep 04, 2012 | Maytag Dryers
Dishwasher makes grinding noise when you turn it on
There is something in the shredder plate under the spray arm. To clear this you will need to remove lower spray arm and then using torx driver remove the screws holding the housing together and remove the housing to get to the debris underneath. Good luck and hope this helps.
Mar 03, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Dishwasher makes a loud grinding noise when running.
Start by pulling out the lower rack. Then pull the nut off the top of the lower spray arm. then remove all of the visible hex head screws. lift up on this section. this should expose another level of hex head screws, then they should be removed and this section should be lifted up. once you reach the chopper blade, remove the obstruction, and put back together.
Mar 13, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Jan 12, 2009 | Maytag Legacy Top Load Washer
Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
Oct 20, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Grinding noise for maytag quietseries 200 usually when it first starts up Our Maytag Quiet Series 300 just started with the same thing. We have had it a little over 2 years. We thought maybe it was the...
It may sound loud and like something is terrably wrong - but when we researched and took the pieces of the sprayer arm out all the way down to the drain - we found 2 small pieces of nut shells - that's it ! They were making the dishwasher sound as if it had something really wrong with it. We removed the nut shells - put all the parts back together - it runs perfect!! Just remember to place the parts and screws in the order they came out - so you put it back together correctly
Jul 01, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Dishwashers Logo
312 people viewed this question
Top Dishwashers Experts
Owen Barnes
