Question about Lexmark X7550 InkJet Printer
I can send faxes but I can not recieve them - Lexmark X7550 InkJet Printer
  • 48 Answers
SOURCE: CAN'T RECIEVE FAXS
Make sure the Auto answer the button is on....
Or
Reset the printer setting to default and set the rings again to 3...and try..
Posted on Jun 26, 2008
  • 77 Answers
SOURCE: i am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Posted on Apr 27, 2009
komguy
  • 2306 Answers
SOURCE: HP 5610 All-in-one can recieve faxes but not send,
Have you set for the proper dialing? there's a choice for pulse or tone dialing, you probably need tone dialing. Also the number needs to be put in just as you would dial on a phone.
Posted on Jul 24, 2009
SOURCE: I can not send or recieve faxes. Ran fax test
you need to find a telephone with 2 conductors and not 4. I tried it and it worked. Cable phone service does not use VOIP it actually uses services similar to the telephone company. Instead of converting the analog signal of the phone somewhere down the street at the switch it converts it to digital at the cablemodem and sends it at different frequency on the cable. It then goes to the cable company and hooks into the regular telephone system.
Posted on Sep 05, 2009
  • 142 Answers
SOURCE: Can send Fax Cannot Recieve a Fax
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01464158&tmp_task=solveCategory&lc=en&dlc=en&cc=uk&product=2512009&lang=en
:) Dr Tony
Posted on May 10, 2010
I can send fax but not recieve fax
Check your Ink cartridge if it is fully empty means it will not print received faxes so it will save in memory
Feb 04, 2013 | HP Officejet 4215v All-in-One Printer
It will send faxes but not recieve them. it is on
Be sure the fax is on the proper phone line. You can send on any line but you can only recieve on the line for your number.
DickyO
Sep 01, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Will recieve fax but wont send a fax
sending fax is free, however you have to have a dedicated fax line with your phone company to recieve.
Jun 27, 2009 | Kyocera Mita KM-2050 Printer
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Can't send any faxes
Hello,Mafriend,It sounds like you might have recieved a Fax machine that Recieved a surge,To verify this Ck the Jack where the Phone line goes in to see if you have any type of discoloration there,also see if it locks up your phone line from making calls or recieving Them ttech
Jul 20, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Lexmark X7550 InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
