Question about Carrier 38CKC042 Air Conditioner
Fan does't work
Air conditioner cooling but fan won't work.
  • 615 Answers
If it is not electrical it is too much dirst, try to clean all dirts using strong air presure hose and use WD40 on the shaft and try to turn it by hand and see if it does move freely...if not you need to change the barings
Posted on Sep 07, 2009
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Froze up now won't cool
turn system off or leave the fan only on and thaw system out, when it is dry, check filter, if not the problem more than likely it was turned down to low or the freon charge is low and should be check by technician.
Dec 09, 2012 | LG LS-L1210CL Mini Split Air Conditioner
Why won't my air conditioner change fan speeds
Having same problem...ac unit seems not to be changing fan speed and cooling level has been reduced ????
I have no solution. but we have just run into the 7 day of 95+ degrees with high humidity. do not believe the units have frozen up, just seems that the fan is in low speed mode and trying to raise it to F2 or F3 doesn't seem to help.??? Most of the time we have to increase temperature because its too cold ?? now it doesnt seem to be cooling the same ??? I await anyones solution.
Aug 06, 2012 | Kenmore 75121 Thru-Wall/Window Air...
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
I have a new ptac that won't cool, why?
The condeser fan blade is broken. I work at a place where 75% of these units have cond. fan broken in same place.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/glenn_a4cc4202f1895fe2
Mar 22, 2012 | Amana PTH123B25AJ Heat Pump Air...
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cooling
Is the fan blowing. If so your compressor is probably the source. If the fan isn't blowing you might have a bad fan motor
Jun 10, 2008 | Maytag M6P09S2ACOM Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
