Question about Whirlpool Duet GHW9150P Front Load Washer
The ball inside the rubber tube, should it be in the tube or above the tube.
  • 5,911 Answers
If you are talking about the ball valve in the drain hose that runs from the bottom of the wash tub, the ball rests inside the large end of the tube and then gets installed to the bottom of the tub. With the drain tube in place, the ball actually resides halfway between the drain hose and the wash tub. This acts as a float cut-off valve to prevent drain water from backing up into the wash tub. If you have further questions, please let me know. I hope this helps you.
Posted on Sep 07, 2009
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
Just took over the lease on a 2010 Lexus is250. Went to fill up with gas and it seemed full. In order to 'fill' with gas I had to stop and start and it took 15 min for 4 gallons. IF there is a...
Check the filling tube (or hose) going to fuel tank for damage. Could be the "ball" just inside the tank where the filling tube is attached. Its there to prevent fuel from draining out of the tank in the event of a roll-over.
Tap on the tank in the area around the filling tube with a rubber mallet. This should "unstick" the ball. They do sometimes get stuck and wont let fuel into the tank.
Dec 02, 2012 | Cars & Trucks
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
My 2004 Envoy, have a water inside the cabin when using the AC.
The a/c has a drain hole under passenger side of dash by your feet above the floor mat. Should be a black rubber tube, this tube goes through firewall to drain water to outside of cab.
Aug 07, 2011 | Air Tools & Compressors
When I'm pumping it up the ball sticks and will not inflate. I hear air coming out from the ball you squeeze.
If this is happening when the finger valve is closed, there is a leak either in the rubber tubing or the inflation bulb. Try putting soapy water on the tubing and then on the bulb. Squeeze the bulb with just your thumb and forefinger, so that you can see any air bubbles. If the leak is in the rubber tubing, you may be able to repair it with a couple of laps of vinyl tape. If the bulb is leaking, that will have to be replaced.
Hope this helps you solve the problem.
Mar 18, 2011 | Health & Beauty
Needs new black rubber tubing connector
my sunbeam model 7660 bp monitor needs a new part on tubing. on the inside of machine there's is a black rubber piece that connects the clear plastic tubes. where can I get a new part? thanks..
May 25, 2009 | Sunbeam Digital Blood Pressure Monitor
I'm having problems removing front axles to a 91 geo Metro. Any suggestions would be very halpful
Getting enough space between the transmission and steering knuckle requires either hoisting the engine and transmission several inches or dropping the lower ball joint. A word of caution on removing the ball joint - the keeper bolt above the ball joint must be removed for the ball joint shaft to come out. Also be careful not to rip rubber boot dust cover on the ball; replacements are hard to find. Unstake the splindle nut and remove it; they are generally very hard to get loose. I suggest an impact wrench, or at least a long 1/2" drive breaker bar. Use a pry bar between the transmission housing and the CV joint to pop the inside end of the shaft out of the transmission; it takes some pressure to pop the snap-ring, but you won't break it.
Jan 26, 2009 | 1991 Geo Metro
Water continues to drip from fill tube after the fill.
Chances are the flapper is leaking. Thats causing the random refilling as the tank slowly loses water into the bowl.
Replace the flapper with only the best available at your supply house. the cheap ones tend to leak even when new. The good ones are less than 8 bucks most places.
If your fill valve has the float ball, there should be a screw right on top of the fill valve at the end of the rod holding the ball to adjust the water level.
Closckwise lowers the level.
Be carefull not to break the plastic ones. If the adjustment is all the way in or does not work, you will need to replace the fill valve.
You could also try bending the metal rod holding the ball, but only as a last resort.
Nov 25, 2008 | Home
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
79 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
