Question about Samsung PCJ534RF 53" Rear Projection Television
TV would shut off after watching it and then I would have to unplug it for a period of time before it would power up again. Now it will not power up at all. Bad power supply?I can hear a relay or something click when I plug it in to the 120v supply.
More than likely a bad capacitor on the power supply board.
Posted on Sep 07, 2009
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
TV Screen 'freezing' while watching.
Most likely the DMD board is at fault. If the DMD board is failing it will hold the data lines in the set down which will cause it to stay on until you unplug it. The part number for the DMD board is BP96-00249A but I suggest you have a technician verify the issue and replace the board as it requires mechanical alignment after wards. Please take a moment to rate my answer. Thank you.
Nov 18, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Stuck on wrong langue and can not change it
try to leave device unplugged for a period of time - this can vary by brand but when you are done watching it for the day - unplug it - when the tv is powered back on after being unplugged it should be back in the default factory setting.
Sep 12, 2009 | Televison & Video
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My tv plays about 1-1/2 hours then shuts down
YOU WILL NEED TO REPLACE YOUR PROJECTOR LAMP #BP96-01472A AND THIS SHOULD RESOLVE YOUR ISSUE.
HOPE THIS HELPS
Jul 07, 2009 | Samsung HL-S5087W DLP TV
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Samsung PCJ534RF 53" Rear Projection Television Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
