Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a conquest side x side w/ice in the door that is about 7 years old. The chute for the ice dispenser keeps getting clogged with ice. We do use the crushed ice option, but it seems that the door to the ice chute isn't sealing very well and letting air in. We do have some water running out of the chute. Not much, but we do keep a paper towel under it. When I break the ice jam out of the chute, it doesn't take very long (a few days) for it to get jammed again.
Rubber seal gasket (door on ice shoot) isn't sealing anymore. Replace with new...although my GE require buying the whole mounting part along with attached rubber seal. Shine a flashlight on the inside freezer door ...facing out through the CLOSED shoot and if you see even the slighest light by looking up into the ice/water dispenser on the front of outer door you will see how much air gets in that way to freezer.
Posted on Sep 22, 2009
I have a side by side frigator, water dispenser works, but ice tray is full but i won't drop
Posted on Sep 07, 2009
Ice chute cloggs with solid chunk of ice over time
Have you had high humidity over the last few months where you live?
This could be normal under those conditions.
BUT.....make sure the door is closing FULLY at the ice dispenser outlet.
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost buildup on area where ice comes out of the ice bin with frost also on the inside of door chute
The flap door where ice is dispensed is warped letting warm air into the freezer causing the frost build up. You must replace the flapper - a $5 - $7 part but not too difficult to replace. I find the flapper last only about 2 years and frost problem reappears. Forget about a "weak heater".
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water dispenser and Ice Maker
it might be your selenoid that closes the ice door in the chute but the water thing is says another thing might be wrong if you need service call 562-688-3627
Oct 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Ice dispenser in door clogged up or frozen
I see this a lot with people who mainly used crushed ice.  It will leave small pieces of ice behind and add up to a clogged situation.  If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear.  Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense.  In this case you may need to replace the solenoid that shuts the door and/or the door.  Let me know what you find.
Oct 15, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
247 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
