Question about Zenith Remote Controls
Tv remote no code
Zenith remote 124-00233-pooa do not have code to reset remote
SOURCE: Re: Codes For Zenith TV
  1. 000
  2. 001
  3. 004
  4. 0051
  5. 0083
  6. 151
  7. 152
  8. 153
  9. 154
  10. 217
Posted on Dec 28, 2007
  • 5568 Answers
SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
Posted on Apr 09, 2008
SOURCE: Code for zenith remote control for toshiba tv
I found the code
Posted on May 22, 2008
SOURCE: Zenith Remote controller
Have a Zenith Remote 124-202-01 with MBR3440 on the inside cover of the remote. I've tried all kinds of numbers and generic numbers without any luck. Anyone know what the code is for my 1995 32" Zenith TV System 3 TV?
Zenith and LG TV support queue in Canada 18885422623 8-5 CST.
Zenith and LG TV support queue in U.S. 18779936484 24/7
Zenith 32” TV System 3 Model Number #SM2771S
Solution: Unplug the Zenith TV for approximately 5 seconds. Remove batteries in the Zenith remote. With the batteries removed press the TV button on factory remote and then the power button 5 times and hold the power button on the fifth time for approximately 10 seconds (I suspect this just clears the internal memory of the remote). Put the batteries back in the remote. Plug the TV back in and the remote should work again. My remote did work again successfully.
Posted on Jun 11, 2008
  • 3 Answers
SOURCE: codes for zenith univ. remote
You can d/l free Zenith remote manual (PDF) here:
Try these codes for JVC tv:
007, 108, 208, 308, 417, 502, 510, 617, 607, 702, 902
Posted on Aug 15, 2008
  • 57 Answers
SOURCE: zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
Posted on May 16, 2009
0 characters
1 Points
What is code for zenith tv?and how do I enter this on remote
If you are trying to use a Zenith remote to control your Zenith TV, the codes are in the remote so no entry is necessary. If your Zenith remote is not working, try replacing the batteries.
Mar 11, 2015 | Zenith Remote Controls
I have a dynex remote control that I need to use on a zenith TV. Can you give me the codes?
Codes to check with Zenith TVs are: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Nov 22, 2012 | Zenith ZN110 Remote Control
Universal Remote Controll Codes for a Zenith TV
These are the codes for Zenith TV: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Aug 04, 2012 | Big Button TV Universal Remote
Samsung AK59-00123A remote to a M261VP vizio tv
[1] Switch your television on
[2] Point the remote control towards the
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
My remote stopped working can it be reset
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
Need code for my tv
Try these codes for a Sanyo tv:
002, 312, 412, 506, 619, 902
Aug 09, 2008 | Zenith ZEN450 Remote Control
Codes for zenith TV.
lost my zenith codes please help, also the manual is now gone ><; please help me .. what code do i use, and how do i input it please, i appreciate the help
Aug 01, 2008 | RCA RC-U703SP Remote Control
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code ( press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Programming remote
The BNZ110 is designed to be for Zenith by default. If it gets changed and won't work, then take the following steps.
1. Remove the batteries.
2. Hold the power button down for 10 seconds.
3. Reinstall the batteries.
This works for many Zenith TV's.
Here are the codes for Zenith if that does not work.
713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 505
Oct 27, 2007 | Zenith DBZN-311 Remote Control
Remote Controls Logo
Top Zenith Remote Controls Experts
andy williard
andy williard
alexander woolfolk
alexander woolfolk
Are you a Zenith Remote Control Expert? Answer questions, earn points and help others
