Question about Vapor TR-6 Steam Vacuum
After i plug unit in it starts continuously tr6 vapor clean
After i plug unit in it starts continuously beeping and doesn't heat up
My unit heats up, has plenty of water, but will not spray, pressure is at 4
Sounds like a blocked nozzle. I would soak it in line Away or used a safety pin to clear it
Apr 28, 2016 | Vapor WhiteWing Steamer Canister Vacuum
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    Why the vacuum shut off after 3 minutes and the plug is hot
    sounds like the motor maybe clogged and over heating. if you can take apart the vacuum and find the motor. if you have a shop vac use that to clean out the dust and debris. put it back together and try it again. if this doesn't work i would replace the vacuum or get it repaired. i would NOT continue to run the vacuum if the plug gets hot after 3 minutes.
    Nov 08, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
    I need operating manual for vapor white wing steamer
    This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is:
    1. Fill the tank with distilled water
    2. Attach the hose to the steamer.
    3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions)
    4. Lock the finger trigger.
    5. Plug it in.
    6. Turn it on.
    7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5.
    8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming.
    For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
    Jun 20, 2012 | Vapor WhiteWing Steamer Canister Vacuum
    Unit not working to heat water--cant hear compressor starting up like normal
    Did you make sure that it was closed all the way? Sometimes if the water canister is not on all the way it can cause this. And depending on how old the steemer is maybe that part went out. But I would check all the lines to make sure nothing is clogged or pinched
    Jun 07, 2012 | Vapor Professionals TR6 Canister Steam...
    No steam is coming out. the orange light is on.
    The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
    Jun 14, 2011 | Vacuums
    Euro-flex monster baby 1000 watt will not release steam
    try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
    Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
    Steam sparging line attached to downcomers on HRSG
    The reason for this is to keep the HRSG warm to reduce fuel costs. Due to the price of Nat Gas, it is adventageous to supply sparging steam to keep the HRSG warm so that when the Comb Turbine is called upon to start the HRSG metal temperature will be greater than ambient temperature.
    Jun 26, 2008 | Vapor 3000 Steam Vacuum
    Vapor TR-6 Steam Vacuum Logo
    87 people viewed this question
    Top Vapor Vacuums Experts
    richie46
    ray gallant
    Tom Chichester
    Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
