Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Repeat message sound
Got a samsung tocco when message comes in it usually repeats message sound till I answer it is only making one sound cannot find how to rectify this G
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
1 then 0 Help Guidance
Command Function
* For Repeat a Message function, press 0 then 1 within about four seconds to
** For Memo Record and Greeting Message Record function, the first time you enter
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
How do you set the answering machine or voice mail on this phone?
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: http://telephones.att.com/documents/product_Product/219/UserManual/1982/1855_manual_bkm.pdf which may or may not work.)
Oct 29, 2010 | AT&T 1855 Phone
I have a samsung tocco lite ,i have been recieeving messages that i have prevuously deleted or recieve the same message over and over again what can i do to stop this ?
HELLO,
The way out of this problem is that you have to get in touch with your service provider and pass the complain to them then those message that have been receive or deleted will not repeat it self again
however, you can also reset your phone with this code as help may be you have mistakenly miss set your phone unknowing *2767*2878#.
Good luck and thanks for using fixya.
Mar 19, 2010 | Samsung Tocco Ultra Cell Phone
Samsung tocco lite only comes up with red bar saying download
the problem is dat your volume button might be stuck or nor working!
Mar 17, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i turn the keypad sound of on samsung tocco
I had the same problem so called Samsung UK. Take following action: Choose - Phone Profiles/Normal/red chevrons/top right drop down menu/choose phone sounds/scroll to bottom phone sound volume, put to zero and press save. It works! Hope this helps. Julie J
Sep 23, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Help
press dial, then press and hold the # (hash) key. This will select silent. Repeat to undo.
Jul 16, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Samsung tocco
Can some one please ell me how to change my answer message on my tocco phone. it says im away and I really need to change it
Aug 28, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
