Question about Microsoft Xbox 360 Console
My xbox 360 when i turn it on the power button goes red
    Problem Solver:
  • 10 Answers
You've got the Red Ring of Death (RRoD error message).
Connect your 360 to a TV or whatever you normally display it on. Try turning it on, and it should come up with a black screen. On the screen there should be an error message. Look at the code on the bottom. This code is extremely important, so write it down. The code will be an 'E' something, followed by two numbers.
Call Microsoft about it, and they can arrange to collect your Xbox 360 for you and send it off for repair. If the console is within a one year warranty, all repairs are free.
If the error is an E74, and you are out of warranty, don't panic! Microsoft have a 3 year warranty included for free, provided you have the E74 error.
The US Microsoft number is 1-800-MY-XBOX, I think.
Posted on Sep 07, 2009
SO MY XBOX 360 ISNT WORKING THE POWERE BUTTON TURNS GREEN FOR A SECOND THEN GOES RED. WHAT IS WRONG?
Try plugging it in correctly but if it has 3 rings you have the rings of death and your xbox is dead.
Jul 30, 2011 | Microsoft Xbox 360 Console
My xbox turns on an as soon as the xbox 360 logo goes on screen it freezes its berly a 2 month old xbox
Are you getting the 'red ring of death' (the red ring that lights up around the power button)?
This could be either a problem with your television set, or more than likely an issue with the Xbox's harddrive.
Jun 29, 2011 | Video Game Consoles & Games
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: when i turn my xbox 360 on the power button turns ...
This sounds like the Infamous Red Ring of Death also known as Rrod. This is basically where your circuitry has just burnt out and has died. You can either take it to a Game Shop to mend it or get a new 360. if you choose the new 360 R.I.P Someones 360
May 17, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Xbox360
This means you have insuffiecient power for your XBOX 360 to work. You need a stronger power source
Dec 25, 2007 | Microsoft Xbox 360 Console
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
55 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
