Question about Maytag Neptune MAH5500B Front Load Washer
Front loader wash machine (Maytide) has a terrible odor, even if the door is left open. Have cleaned it out with clorox and even the cleaner for front loader but with no success. Any solutions?
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Posted on Sep 28, 2010
Water remains in hose and smells
Front loaders are known for bad odors. Run an empty cycle with double bleach and let the machine totally dry out, with the door OPEN. The bleach will kill the mold spores and letting it dry out will prevent more from forming.
Dec 19, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
My machine works great is 4 years old, smells moldy, tried to leave the door open to dry out, tried washing with washing machine cleaner, tried clorox!!!! what can we we do to get rid of the odor? Thanks
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$&**
Aug 24, 2010 | LG WM-2277HW Front Load Washer
Wet towels were left in washing machine (with door closed) for 2 weeks. The odor is terrible. I have tried washing with clorox and also vinegar. Help!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Gunky slim in rubber gasket on front door. terrible odor also
that is mold bleach water hand wash rinse with water . afresh cleaner several times then monthly
Feb 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
147 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
