Question about Hotpoint WF430 Front Load Washer
Hi I am looking for the filter that collects debree from the rinse water in a hotpoint wf430
    President:
  • Hotpoint Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine, for the 420model. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Posted on Jun 06, 2010
Hi i was just wondering how to clean the filter on a fisher and paykel washing machine. when washing clothes the washer doesnt seem to be getting them as clean as they could be and there is always debree...
There is no filter to clean on GWL11. There is an optional lit filter that can be installed that goes in-place of the fabric softener cup. I would guess that the reason debree is being left behind is possible due to the over use of soap... This is a high efficiency machine and if you are using the auto water level option it may not be using as much water as you believe it should (or would). The debree get suspended in the soap suds as the should however, there is too many of them and they are not all being rinsed out. You could try using the fabric softener rinse option even if your not using fabric softener this gives it a more traditional rinse like most other top load washers use.
For really soiled clothes like sand and dries mud etc. shake the clothes out first.
I hope this helps.
P.S. I actually have this exact washer myself.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine not rinsing and spinning wf440
I would suggest that you check and clean the pump filter.
This is to be found by removing the lower panel of washer, then remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint WF430 Front Load Washer
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Hotpoint WF430 lights flashing will not start
Hi, the problem is the pump is blocked. What you have to do if your a bit handy is to turn off the power from the plug socket, pull out the machine and take off the back panel, then when you look iside you will see a big black rubber fitting at the base of the mashine attached to a white plastic pump and inturn to your outlet pipe. you have to disconnect the big black one from the top, there is a metal clip which you have to unscrew and it will fall down. inside this is a plastic ball and something which looks like a shuttle ****, take this out and clean everything, you will be suprised what is in there (especially if you have kids) lastly put everything back together and put on a quick rinse cycle. all is fixed! OR Call an repair man, who may try to con you into new parts when they are not neccesary.
Jun 05, 2009 | Hotpoint WF430 Front Load Washer
Hotpoint wf430
Had similar problem. Blocked filter and faulty pump, clean filter replaced pump approx £25. Took about 20 mins
Jul 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hight water level on rinse stage
hi there sounds like you may have a faulty pressure switch, this is located at the rear of the soap dispeser box under the lid.
May 25, 2008 | Hotpoint WF430 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Water coming out of dispenser drawer!!
You said you took off the hose from the back, okay this hose was clamped somewhere below - this is where the block is. Your outlet filter. It requires periodic cleaning - is a place where you can remove (see manual 'cleaning filter')to clear out whatever. For many front loading machines the place to open is at the front panel, right or left bottom, a 4.5 by 4.5 door. Clean out, refit.
May 16, 2007 | Hotpoint WF430 Front Load Washer
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Mar 30, 2007 | Hotpoint WF430 Front Load Washer
Hotpoint WF430 Front Load Washer Logo
212 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
