Question about Dryers
Gas dryer heats for 10 minutes then heat goes off
My Amana Gas Dryer, heats when it is initially turned on and then the heat quits after about 10 minutes but the dryer continues to tumble. I have check the venting which is about the only thing the users manual suggests.
  • 60 Answers
It's doing what it's supposed to do. you should use a different setting.
Posted on Sep 07, 2009
Hello Fixya, I just moved and my new place has an amana 120-V Gas Dryer, that turns but won't heat. Ignition would bes suspect #1. Any great ideas? Thanks much, Rob
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 31, 2011 | Amana ALG866SB Gas Dryer
Amana dryer, no heat, drum turns, timer not advancing
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 13, 2010 | Amana DLE330RAW Electric Dryer
Amana dryer NED7200TW quit heating, it appears everything else is working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Amana NED7200TW Electric Dryer
Not heating correctly. Will heat for a few minutes on the hottest setting and then discontinue heating.
heatman101
Sep 20, 2010 | Amana Dryers
My heating element in my Amana dryer will heat up for a few seconds, but then goes back out. What should I do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Amana NDG5800 Gas Dryer
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
heatman101
Aug 28, 2010 | Amana Dryers
We are having a problem with our dryer not heating up. It wuill turn on and run for a few minutes and then it will beep and the letters h5 show up, what does this mean?
heatman101
Aug 27, 2010 | Amana NTW5200 Dryer
My amana gas dryer quit drying
heatman101
Aug 08, 2010 | Amana ALG643RB Gas Dryer
Intermittant Heat on Gas Dryer
Check the venting tube. It maybe clogged full of lint somewhere inside of it. If so the moister contro sensor will shut off the burner within due time such as yours
May 01, 2010 | Maytag SDG4606A Gas Dryer
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
