Question about Video Game Consoles & Games
Disc doesn't want to go into the wii console, but you can shove it in. After being in the console it won't read the disc. It will also not eject.
    Genius:
  • 1,689 Answers
Hi dennis,
you are facing a serious issue with your Wii, this is an issue with the disc feed assembly and i personally as a Wii user have not come across this issue being fixed as home. the links will just give you some information on other related Wii issue. Else the best thing you want to do is bring it to a repair shop certified by nintendo.
http://wiinewz.com/forums/d2pro/73246-wii-doesnt-insert-the-disc-correctly-and-doesnt-start-to-spin-immediately-video.html
http://www.wiichat.com/nintendo-wii-hardware/5362-wii-disc-loading-problem.html
http://www.wiierror.com/diskerrors.php
Posted on Sep 07, 2009
The Wii will not read my disc
Situation:
The Wii console will not accept game discs or the discs are ejecting immediately
What To Do:
Press the eject button on the front of the console. The console will not accept any discs if there is already a disc inserted, and it is common to forget that a disc was already inserted.
If the system still won't accept discs, or if the discs are immediately ejected, this indicates a problem with the mechanism that pulls the discs into the system and the Wii will need to be repaired. To begin the repair process, click here.
Nov 15, 2012 | Nintendo Wii Console
What is wrong with my wii says this an has error occurred press the eject button remove the game disc and turn off the powe to the console please read the wii operations manual for further instructions
This error most often effects homebrewed Wiis. If you do not have homebrew installed on your Wii, and have not hacked it in any way, then you might have luck doing a system update. If that doesn't work, you'll probably want to contact Nintendo support.
Jan 09, 2012 | Nintendo Wii Console
I accidentally inserted a disc the wrong way in our Wii console and cannot get the disc out now - the eject button won't work, what should I do?
Check if you can see a small hole on the media drive or optical drive. Use a paper clip to manually eject the disc.
Hope this can resolve your concern.
Jun 26, 2011 | Nintendo Wii Console
The disc will not eject and the wii says to insert a disc
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform: http://www.nintendo.com/consumer/webform...
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
It is possible that you inserted the disc incorrectly. That would account for the error message "Unable to read the disc" or "Disc could not be read." But it should've ejected on its own.
Before calling Nintendo Service you can also see if their Support site has any solutions. Try the link provided in the source.
Good luck.
Dec 29, 2010 | Nintendo Wii Console
Unable to read disc I have 20 something games it wont read any of them
Here are the steps that worked for some:
1. Completely power down the console.
2. Power up the console and get to the Wii Menu.
3. Eject any disc currently in the console.
4. Press the eject button again, without any discs in the drive.
5. Insert the disc that you would like to play.
If this doesn't work then contact Wii customer support.
Jan 10, 2010 | Nintendo Wii Console
Disc won't eject
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 20, 2009 | Nintendo Wii Console
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
