Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine stalls when blade is engaged
The engine stalls when I engage the blade and take my foot off the brake. There must be a sensor going bad.
  • lafield Sep 07, 2009
    I am sitting on the seat. brake on, but in 1st gear with blade disengaged. If I engage the PTO with the brake on, all is well. The minute I take my foot off the brake, with the PTO engaged it sometimes cuts out and other times runs. If I quickly disengage the PTO the engine resumes. I am not thinking it is the seat sensor, but not sure.
  • A Miller May 11, 2010
    This is a universal comment, not necessarily specific to your machine. There is an "operator presence" switch in the seat. I presume you are sitting on the seat when you engage the blade? To run this machine you MUST depress the "brake" (sensor #1) to start and you must remain on the seat for it to run at all. Sensor #2 is in the seat. Even if the "brake" is set the blade (clutch)must be disengaged for you to dismount and keep the engine running. I presume I'm not telling you anything you don't already know to this point. I'd check the seat sensor. It is generally a simple switch. You can short it out to test, but DON'T LEAVE IT IN THAT CONDITION! The switch is there for your safety and the safety of your children!
  • Craftsman Master
  • 8,404 Answers
I think you have found your trouble. Lift the seat and check the wiring. My Troy Bilt (Old Troy not MTD Troy) tilts forward making the switch and wire accessable.
Posted on Sep 07, 2009
  • 313 Answers
The best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
  • wayneweb Jun 27, 2014
    After I had run it out of gas and put some more in, the mower would backfire and die. I finally discovered that my three-tear-old grandson had stuffed an aluminum gardening implement into a space in the frame. The mower worked fin when I took it out....
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Why does my rover rancher stall when i go to engage the cutting deck
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Feb 17, 2015 | Garden
Lt200
Sounds like you may have some internal engine issues. Check your spark plug(s) to see if they are oil soaked. If so, you may have some issues with the engine.
Jul 22, 2017 | Craftsman Garden
Engine stalls when blade fully engages
its a bad safety switch adjustment you can remove the wire to test it only LoL
May 20, 2012 | Snapper Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Engage blades makes noises
Sounds like the bearings are going out in one or both of your blade spindles. With the belt off,(and engine, of course) engage the lever on the dash. That will release the blade brake so the blades will be free to turn. Spin each one by hand. It will be easy to tell if the bearings are bad.
Jun 06, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
544 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
