Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
We have a film on the dishes after the cycle, the water heater is on without water in the tub
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Sep 09, 2009
  • 5,603 Answers
The heater is on after a cycle to sterilize and dry the dishes. This is normal.
Are you using a sheeting agent such aas "Jet Dry" in the dispenser (it is usually filled by a plug on the door).?
Posted on Sep 07, 2009
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Dishwasher leaves a white film on didhes and film will not come off.I have drained water heater for about 20 mins to remove calcium deposits but problem still exists.
Start a wash cycle with no dishes and no soap.
Once the machine fills with water and starts washing,open the door and pour in one quart of WHITE vinegar and resume the wash cycle.
Change your dishwasher detergent to the ELECTROLUX brand.
It has added chemicals to combat the problem you describe.
The government mandate to remove phosphates from dishwasher and laundry detergent has resulted in unclean appearance of dishes and laundry.
Apr 05, 2011 | GE Dishwashers
Dishes have residual film after wash cycles. Grease has formed in the bottom of the tub and around the gasket and appears to be coming from the center of the machine where the motor-geardrive in located....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 08, 2011 | Maytag 24 in. MDB8600AW Jetclean II...
I have a Kitchenaid dishwasher Model KUD101lLWH6 - Serial number FR4205761. I have not changed soap or rinse product since I got the dishwasher but I am getting a white looking film throughout the...
The white film that you are talking about could be two things. First is the quality of your water, having sediments either through the water system or from the water heater because the water that goes into the dishwasher is taken from the hot water supply. Second is the build up of soap residue and even with a rinse product it is not able to remove it. A simple remedy is to due a wash and rinse cycle without dishes and put vinegar in the dishwasher about a cup full (8 oz) and see if that will help. If not I would check the water and going in and out of your water heater. Good Luck
Jan 06, 2011 | KitchenAid Dishwashers
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Dishwasher leaves a soapy film on the dish's.
ok i run a appliance repair company DENTON appliance and your problem is simple you have a water temp problem the are two thermo sensor under the bottom of the tub one or both are bad causing the heater not to come on to heat the water. it could be a bad heating element but you would be able to see a burned spot on the element. it takes hot water to remove the soap film this should fix your problem.
Feb 18, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Feb 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish Washer not cleaning
white film generally shows that there is not enough salt in the dishwasher, this is not normal salt like on your meal, you buy this from the detergent section of the store, add salt through the part where it says "S" unscrew the cap and put about 2 cups of it in, while filling with salt water will overflow out of the same place, this is normal this will start to work after about a wash or so if the salt is fine then check the heater on the machine, make sure its warming up etc if i have helped please rate me
Oct 03, 2007 | Dishwashers
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
96 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
