Question about GE PDS22SCRRSS Bottom Freezer Refrigerator
GE PDs22SCRBRSS is making clicking sound every one to two seconds. Sound is coming from the back by the tech panel.
  • 430 Answers
Sounds like your evaporator(freezer) fan motor is bad. Also notice, the main control board has no.s of relays on them, when the relays go somehow energised, then the clicking cound appears. To resolve, replace The Main Control Board and the Defrost compressor. Also notice is the sound " hmmmm " and then " click " and a break for a min and then again, then the compressor has badly failed. Also notice that is the refrigerator lights get dim on dispencing ice or water. If yes, the Main Control Board is the culprit. It is also seen that the curcuit board behind the fridge has broke. Please reply me for further doubts. Regards, Nandini.
Posted on Sep 07, 2009
Tip
Appliance Repair Boise - GE refrigerator making clcking noise
When you hear your GE Profile refrigerator making a clicking noise, coming from the back/rear of refrigerator, your refrigerator control board is bad. If your refrigerator and freezer are still cooling then you are lucky and you might have a few days to get that control board replaced. The clicking sound you're hearing most of the time, comes from a small panel located on the rear of refrigerator. Remove 3 screws and replace.
Rich
Western Appliance Repair Boise
on Oct 11, 2010 | Refrigerators
Gsh25jsrf side by side ge it is making a buzz clic clic from the back buzz from compressor clic from circuit board came back on after spinning the fan worked for a night then back to noise and not working
it sound like the compressor is overheating and the start relay could be failing because of the holiday and possible not getting a tech out there, pull the frig out from wall and remove the back panel and get an portable fan and let it blow air on compressor to keep it cool, If you here the sound on the covered axcess panel on the back the mother board is questionable. Hope this helps....
Dec 24, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Model # GDL20KCSABS clicking sound
The control board is going out . Pt # WR55X10656 . Soon , you will start having a refrig problem . Probably already started , but , not obvious yet .
Aug 26, 2009 | GE Refrigerators
Continuous clicking sound and light flickers with each click
Replace the main board (mother board) WR55X10656 behind the panel on the back side of the refrigerator.
May 30, 2009 | GE Profile PDS22MBS Bottom Freezer...
Clicking noise approximately 1 second apart
That clicking noise is possibly your compressor overload kicking off because it cannot start the compressor. Most times the start relay or the start capacitor are defective. But because your refrigerator has a mother board located on the back and behind a panel. We need to consider the board is going out. Unplug the refrigerator and pull away from the wall. Remove the screws on the rear panel to expose the mother board. Need to look for burn marks on both sides or a signed that a relay has been over heating. The board is part number WR55X10656
a5ba56b.jpg If we find the board is OK, we can check the other components mentioned, Thanks, Sea Breeze
My Site-> http://servicepartstec.blogspot.com/
May 28, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE 35GT740 35" NO SOUND
Did you try turning up the volume on the remote or front panel?
Also, try unplugging the TV from the AC outlet for about 15 seconds to make the TV do a re-set.
Beyond this, there is most likely a failure and the set will require service.
Jerry G.
Apr 10, 2008 | GE 35GT740 35" TV
31GT740
The GE (actually RCA) 31GT740 uses the CTC203 series chassis. The first thing I would do is resolder the coil on the base of the horizontal output transistor and the pins of the horizontal drive transformer, as well as any other solder joints on the main PC board that look weak or cracked. 9 times out of 10 that cures the symptoms you described. If you do not have experience soldering parts on PC boards then have a qualified tech handle it for you.
Jul 26, 2007 | GE 31GT740 31" TV
CMT-RB5 - No Sound
your set as a problem in the audio circuit. the audio ic or transistor output needs to replaced.call a tech to do the repairs.good luck.
Apr 11, 2007 | Sony CMT-RB5 Shelf System
GE PDS22SCRRSS Bottom Freezer Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
