Question about Dell 1815dn All-In-One Laser Printer
Hi My Dell Laser 1815 is having a paper jam problem each time it tries to load the paper from the tray.
The paper tray itself is probably missing a small peice. Look towards the front of the tray... there is a guide (about 2" wide) that, if you push down, it springs back and forth. My tray was missing a small peice of flat metal that popped off. The feed roller rests on this piece when the tray is loaded. If the piece is missing, then the roller is to close and the paper cannot make it through into the printer. Still looking for the part number....
Posted on Sep 23, 2009
Our 1815dn reports paperjam due to static electricity, that makes the paper stick. Obviously this is most prevalent in the winter during dry days.
The solution is pull out the paper tray, pick up about half of the stack of paper in the tray, turn in over and put it back in; this way you reverse the polarization, and the printer will (at least for a while) stop reporting non-existing paper jams.
Posted on Dec 21, 2009
    Problem Solver:
  • 10 Answers
I am not familiar with this model, however!
Do you have a mulitpurpose tray, or a tray1 where it unfolds and you can insert paper that way? If you can test some prints through there and it works perfect, thats good! If so, move on to the actual tray testing.
The tray for the paper may have Paper Guides which not only set the size of the paper, but also tell the printer what type of paper is in there. Remove all paper and verify that the guides are set properly.
All paper trays use a type of pick-up assembly, Inspect the rollers and make sure they are seated properly. There may be a roller in the tray itself, and or Above the tray. As in, you pulled the tray out, and if you look UP in there, you should see an assembly.
Sorry this information is so vague, but generally most laser printers follow that type of build. At the very least, maybe you can verify something here, or clarify for dell laserjet expert to assist you with ;)
Posted on Sep 07, 2009
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
Aug 28, 2007 | Dell 3100cn Laser Printer
Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
Feb 06, 2010 | Dell 1815dn All-In-One Laser Printer
I have a Dell 3100cn that will not print as it continually states Load Tray Letter. The tray is loaded, I have rebooted multiple times any other thoughts?
The paper sensor is likely malfunctioning or there is a paper jam causing the printer to "think" that there is no paper in it.
Oct 15, 2009 | Dell 3100cn Laser Printer
Dell 1815 All in One Printer Says No Paper When Paper is Full
Most likely the printer is asking for paper in the Manual Printer Feeder (not the tray). Try put paper in the MPF.
CHeers
Sep 01, 2009 | Dell 1815dn All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
PRINTER DID NOT TAKING PAPER AFTER PRINT OPTION AND PRINTER STOPS AFTER 2INCHES PAPER
hi
I guess its a coz of paper jam in your printer.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new **** of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
hope u will b helpffull
thankyou.
May 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
1,892 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
