Question about Nokia 5165
5165 keypad locked ans will not respond to unlock and then * key. help?
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
How can I lock the keypad?
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Hope this help and if helpful RATE please
Feb 22, 2011 | Nokia 6310i
What is the default password for micromax x2i mobile
The Keypad Lock Icon is seen on top of the screen at various positions depending on the number of icons displayed. An Open Lock signifies that the phone’s keypad is unlocked and a closed lock signifies that the keypad is locked. You can unlock the keypad by pressing Unlock (by right soft key) on the phone, followed by the Send (GREEN) key. Similarly for locking the keypad, press the End (RED) key, to be followed by the Send key.
The user guide for your phone does not indicate a default pass code. Most default passcodes are either 5 or 6 zeros. Some are 12345.
See user guide:
http://www.micromaxinfo.com/downloads/guide/X2i_UM.pdf
Jan 26, 2010 | Cell Phones
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Lock the keypad
K800i To manually lock the keypad:
  2. Select "Lock keys".
  1. From standby, select "Menu" > Settings.
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Keypad locked out
Consult your owners manuel for turning off the sabbath mode feature.
try to remember the whole f1 code. if it was f1-1 it could be a temperature problem
if it is f1-4 is could be a shorted keypad
the control pad could be locked out as well. try holding the cancel key for 3-5 sec to see if it unlocks the control
Feb 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
Razr not responding to any key strokes
you have a defective keypad flex or loose its connections,,,
Oct 26, 2007 | Motorola Mobility RAZR V3
Nokia 5165 Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
