Question about Maclaren Baby Gear
Can I get relpacement wheels - Maclaren Baby Gear
I have a flat back right tire on my mac3 stroller...i need to know were i can get a replacement or replace all
Posted on Apr 29, 2011
    Scholar:
  • 195 Answers
On Ebay is a listing for the following:-
140341029015
MACLAREN TECHNO/XT/CLASSIC/XLR SET OF WHEELS 05/06/07/8 Regards
Alan Hood
ami-man
UK
MACLAREN TECHNO/XT/CLASSIC/XLR SET OF WHEELS 05/06/07/8 MACLAREN TECHNO/XT/CLASSIC/XLR SET OF WHEELS 05/06/07/8
Posted on Sep 07, 2009
Does it need a security code in order for the car to run
check owners manual, these cars today have a dam button for everything, is there some button on your steering wheel, BUT make sure all connections to starter & battery are correct. if you have a security system in your car it may think your trying to steal it. call a dealer for assistance, if you can't get it resolved thru fixya .com, good luck, ps others have this same problem, look around @ other websites
Feb 02, 2013 | 2004 Chrysler Pacifica
Wont start, clicking and all dash lights on. relpaced starter no go.
check the starter and ignition fuse. starter fuse is located in the fuse box in your engine bay, ignition fuse is located in the kick panel which is right under your steering wheel.
May 17, 2012 | 2006 Dodge Durango
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
I have a 2003 LS Sport Impala I have relpaced the front wheel bearings twice and have lost the humming noise but still have an issue with the ABS and traction control warning lights being on. I had it...
WHEN YOU PRESS THE BRAKE PEDAL DOES THE PEDAL SEEM TO JUMP? IF SO THE MODULE HAS SEEN A WHEEL SPEED SENSOR MPH DROP SIGNALING A BRAKE LOCK UP . OR LOSS OF WHEEL SPEED , IF THATS THE CASE THE MOST COMMON PROBLEM IS A BROKEN WIRE IN THE VEHICLE HARNESS NEAR THE WHEEL SPEED SENSOR CONNECTOR USUALLY WHERE THE HARNESS MAKES A U TURN UPWARDS .
IS THE ABS LIGHT ON ALL THE TIME ORDOES IT RESET WITH A KEY CYCLE?
FIRST OF ALL THE TRACTION CONTROLL AND THE ABS SYSTEM ARE BASICALLY THE SAME SYSTEM.
THERE SHOULD BE SERVICE CODES FOR THE MALFUNCTIONS , FIRST THING IS TO RETRIEVE ALL ABS CODES THEN MONITOR WHEEL SPEED SENSOR INPUTS WHILE DRIVING
HOPE THIS HELPS
Aug 08, 2010 | 2003 Chevrolet Impala
Steering
Since this is front wheel drive I have to say yes. You have a bad CV joint. That clicking sound is typically a bad CV joint or one that was improperly installed. Take it back to mechanic that did the work and make him do it correctly.
Feb 21, 2010 | 1992 Mercury Sable
I want to take apart steering wheel to relpace cruise control unit
remove top and bottom cover. screws that hold steering wheel horn cover are accessible from behind steering wheel, you will need a puller, can be rented at auto shop, disconnect battery as horn circuit is not switched
Oct 26, 2009 | 2001 Ford Explorer Sport
I have a bolen lawn tractor model blm761f, after 30 min. of mowing it does not transfer power to the back wheels, if I snap the cluch it help some what for a short period of time. what needs adjustment
It sound like the main drive belt is worn out and after 30 min it is warn enough and stretched enough that it is not making good connection, for the most part this is a remove and relpace problem because once they start to slip it gets nothing but worse. Hope This Helps Don
Sep 21, 2009 | Mtd Garden
Need to relpace lug nuts, what is needed to remove the hub?
Huge, really ugly job, because this is one of the worst design flaws I've ever seen... and I'm assuming we're talking about the front wheels. Get this. You have to separate the hub from the steering knuckle using a hub puller designed specifically for the Capri (it's in the Ford tools catalog). Then once you've replaced the lug (and/or the brake rotor and/or the wheel bearings and/or the wheel seals - because all of those require the same proceedure too) the hub needs to then be pressed back into the steering knuckle using a hydralic (or similar) press... which no doubt would consist of also pulling the knuckle to achieve). Impressed? Yes, so was I.
Jul 28, 2009 | 1993 Mercury Capri
Dodge Durango 2003 a/c not cooling relpaced a/c
No offence but did the system get refilled properly?
Also be sure the blend door under the dash is moving corectly and completely
Jul 05, 2009 | 2003 Dodge Durango
Problem with Lexmark wheelwriter 3
Remove the P/W and look for debris down in the slot it fits in, if you have some sorce of compressed air blow the printer out especially the P/W area. If this dosen't help you probably need a tech to relpace the sensor.
DickyO
Aug 25, 2008 | Lexmark Wheelwriter 3 Typewriter
Baby Gear Logo
1,336 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Jim Goldsmith
Jim Goldsmith
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
