Question about LG WD-3274RHD Front Load Washer / Dryer
How ca i request for a manual book for LG portable washer and dryer(model#3274RHD)?
  • 5,911 Answers
If an owner's manual is all you need, you can go to managemyhome.com and type in your model number under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can print or download for FREE.
If you need a troubleshooting guide, they usually come with the appliance and are placed inside the washer cabinet for maintenance technician use. It will be affixed to one of the interior cabinet walls or will be located behind the lower panel under the door.
If you have questions, or require additional assistance, please let me know. I hope this is helpful to you.
Posted on Sep 07, 2009
How do i stop the cd cycle
On my machine, CD is the Cool Down stage after it's finished drying. The machine just sits there with CD on the display until you press the play/pause button. Then CD goes away and you have to wait two F****** minutes until the door unlocks.
Mar 15, 2012 | LG WD-3274RHD Front Load Washer / Dryer
My Lg WD-3274RHD after a load is complete It fills with water again? If left ovder night water will run out the door.
I have same problem with my washer/dryer combo.It took me quite some time to figure out what is going on.Did all electrical checks ,everything was fine and worst thing it was intermittent thing ,it would do it 8 out of 10 times. Found cold water inlet valve assembly to be faulty (mechanical problem with middle valve) . Second time in 6 years ,other than that I'm very happy with that combo.Problem now is to get new valve, because it is not available anymore from LG, so I'm digging through internet to see if anybody has it somewhere. Good luck
May 06, 2010 | LG WD-3274RHD Front Load Washer / Dryer
THE WASHER DOES NOT COMPLEAT THE CYCLE IT STOPS AND Codes IE
Are all taps turned on, is the filters in the hose connections clean? The code means it is not getting water, if water supply is ok one of the valves may be faulty.
Apr 18, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Where can I get the bolts for the spider ( inner drum )
Hello. Go to Sears Direct, enter your model number and look at the parts diagram for your machine. Find the bolts you need and order them. Joe
Mar 31, 2010 | LG WD-3274RHD Front Load Washer / Dryer
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
How do we clean the dryer 's filter?
I think I know what you mean - the machine itself does not have a lint filter and over time I've noted that it can build up around the large rubber door gasket. You will simply need to be more fastidious about cleaning it out after each cycle. I've had success using an old toothbrush dunked in some water to get the stuff out. The washer's filter (located in the lower left corner of the machine) only traps large solid debris. Hope that helps!
Jun 26, 2009 | LG WD-3274RHD Front Load Washer / Dryer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LG WD-3274RHD Front Load Washer / Dryer Logo
143 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
