Question about Applied Microphone Technology AMT 1/25 1957 Chevy Hardtop : 31543
Correct order of spark plug wires on a 1957 chevy
  • 41 Answers
1-8-4-3-6-5-7-2
Posted on Sep 09, 2009
No fire to the coil packs on a 05 Chevy impala 3.8
You can try unplugging one of the spark plug wires from the coil pack and then touching it to a metal surface, you should see a spark. If you do then that wire and plug are good. Do this to each wire to check for spark. If they all have spark, ensure that they are plugged in the correct order. If they are you may have a faulty coil pack. You can pick one up on ebay super cheap.
Sep 05, 2016 | 2005 Chevrolet Impala
1989 chevy k1500 wont start after changing distributor and rotor
very good but did you check that the no1 piston was on tdc firing before you replaced the distributor . You may be 180degrees out on the firing order.
Apr 09, 2014 | Cars & Trucks
Correct spark plug wiring diagram
Firing order for a 305 is 1-8-4-3-6-5-7-2. The distributor turns counter clockwise and #1 should be the 5 o'clock position looking down at the top of the distributor.
Jun 29, 2013 | 1986 Pontiac Firebird
If i have a 1996 chevy cavalier i have the firing order for the spark plugs but need the order for the distributor or ignition coil
Firing Orders
  • Sending Units And Sensors
  • Starting System
  • GM Cavalier/Sunfire 1995-2000 Repair Guide
    FIRING ORDERS
    Print
    See Figures 1 and 2
    To avoid confusion, remove and tag the spark plug wires one at a time, for replacement.
    If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes to reflect how your engine is wired.
    Fig. Fig. 1: 2.2L (VIN 4) Engine Firing Order: 1-3-4-2 Distributorless Ignition System
    Apr 16, 2013 | 1996 Chevrolet Cavalier
    No spark to engine 1991 ford pickup
    It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
    Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
    To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
    Click the link below:------
    Car cranks, has spark but will not ?
    http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
    The spark plug firing order for car?
    http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
    How to Replace Spark Plugs?
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
    How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
    http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
    Car has no spark?
    http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
    How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
    http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
    No spark on 2008 Chevy Avalanche?
    http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
    How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
    http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
    Ford Plug Wires Not Coming out?
    http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
    Ford explorer has no spark?
    http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
    Chevy impala spark plug firing order diagrams?
    http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
    How to gap spark plug on Chevy Impala?
    http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
    Spark plug Replacing for chevy impala?
    http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
    Chevy s-10 blazer 4.3l Spark Plug Firing Order?
    http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
    1982 dodge rampage Spark plugs Firing Order Diagram?
    http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
    2006 Suzuki Forenza Spark plug Firing Order Diagram?
    http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
    1983 Ford Ranger Spark plug firing order?
    http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
    Firing Order for 1991 Lexus ES 250?
    http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
    Firing order for 1992 Chevrolet 5.0 engine?
    http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
    How to identify number one spark plug on the distributor cap?
    http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
    How to remove rear spark plugs on 1991 Buick Regal?
    http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
    These details will help.
    Thanks.
    Nov 26, 2012 | Cars & Trucks
    Wiring diagram for sparkplugs on 2001 kia optima v6
    For spark plug problem, click the help links provided below: ---
    Car has no spark?
    Car cranks, has spark but will not start?
    How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
    Spark plug Replacing for?
    How does the spark plug wire go on the distributor cap?
    This will help.
    Thanks.
    Feb 05, 2012 | 2001 Kia Optima
    I took of*** my spark plug wires working on my small block 350 pickup and I don't remember the the firing order to put the new wires back on. Is there a diagram anywhere or is it even that difficult to...
    Next time number each lead before you remove it and no. the dissy cap as well
    The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
    On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
    The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
    See the diagram; Click to open a printable larger image in a new window. The firing order starts with the number one cylinder. We would connect the number one spark plug wire to the distributor cap terminal in the 6:30 position. distributor.pngSince the next cylinder in the firing order is 8 (passenger side rear), we connect the number 8 spark plug wire to the next distributor cap terminal (approximately 7:30 position) in the clockwise direction from number one. You need to be sure you continue the firing order in the clockwise direction around the chevy small block distributor cap from the last installed spark plug wire. Setting the rest of the firing order is just a matter of repetition. Be sure to count the spark plugs from front to back on each side of the motor to identify the correct cylinder number in the firing order.
    Jun 21, 2010 | Cars & Trucks
    Applied Microphone Technology AMT 1/25 1957 Chevy Hardtop : 31543 Logo
    87 people viewed this question
    Top Applied Microphone Technology Toys Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you an Applied Microphone Technology Toy Expert? Answer questions, earn points and help others
