Question about Craftsman 20 hp 42 in. Deck Yard Tractor
20 hp craftsman - no power. New fuel line, new plugs, clean air filter, fresh fuel. What next?
  • A Miller May 11, 2010
    Briggs engine? Check the fuel pump. Replace the fuel filter if you didnt already.
  • 313 Answers
Have you checked inside the fuel tank for any blockages at the connector drain hole where the fuel is fed to the engine as you could have some debris there.
Posted on Sep 07, 2009
Craftsman Leaf Blower will only rev up about 1/2 power at full throttle. Any suggestions?
If this is a two cycle engine there are adjustment screws that set the fuel mixture when the throttle is depressed.
Dec 02, 2016 | Craftsman Garden
I have a model # 917.289720 mower. It dies while cutting. Just did a tune up, fresh gas, new fuel fiter, spark plugs, air filter. HELP !
Take off carb and clean it assuring ports and orifices are not plugged, its starving for gas ! Main jet. Water bubbles in gas? in bowl? Drain.
Apr 10, 2013 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a Craftsman 42" mower with B&G 19.5 hp
pull fuel line from carb. turn over a few times to see if fuel pump is working.As the motor turns fuel should be pumping, if your gettin fuelinspect carb.If noy gettin fuel backtrack fuel line.
Oct 22, 2012 | Garden
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Will not start after putting on new fuel filter and spark plug
This may seem silly, but if you put a new fuel filter in, did you drain the fuel and not put fresh fuel in the tank, and is the plug wire connected properly?
Good luck.
Jul 19, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 15.5 HP, Craftman lawn tractor. I'm having problem with it staying running. It will run just find for 20-30 minutes and then stop abruptly. I have changed the spark plug, oil, cleaned the air...
Check the Blade Safety Switch. Also check if the Carburettor requires a good cleaning and overhaul or not. After that check if there is any air leak or air in the fuel line.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My craftsman riding lawn mower conks out even after we have changed the air filter, deck belt and fuel filter -
clean the carb and make sure the fuel filter is not got something in it...or the fuel lines before it.
Aug 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
73 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
