Question about GE WSXH208A Front Load Washer
Clothes are still wet after a spin cycle in my front loading washing machine
  • 60 Answers
You can do any of these things.
use less clothes
use higher heat setting
dry clothes twice
or CLEAN THE LINT FILTER
Posted on Sep 07, 2009
  • 96 Answers
SOURCE: series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Posted on Mar 20, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
IrishDruid
  • 2712 Answers
SOURCE: Spin cycle not working properly, clothes still wet!!!!
When the clothes are wet at the end of a cycle, check these:
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Posted on Oct 29, 2008
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
  • 6 Answers
SOURCE: Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Posted on May 08, 2009
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | Washing Machines
Spin cycle is not working. clothes are soaking wet when cycle is finished.
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
It doesn't self balance and spin out all the water from clothes. the clothes are very wet, especially jeans. And the washer rocks bad during the spin cycle.
heatman101
Oct 20, 2010 | GE WSXH208A Front Load Washer
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
heatman101
Sep 16, 2010 | Kenmore Washing Machines
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
GE WSXH208A Front Load Washer Logo
216 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
