Question about Vizio VX32L Television
My remote will not work
I have a 32 inch vizio and my remote stopped working for some reason i have changed the batterie and no luck and the came with the TV but i cant even try to put a new code or anything can someone help?!!!!!!!!!!!!!!!
  • Vizio Master
  • 1,294 Answers
Dessasembly the remote control:
1.Clean,use the izopropilic alcool or 75%alcool or finest wisky the remote taste rubber pad.
2.Assembly the remote control,change the batteries(see the polarity).
3.Near on functional in the FM or MW radio (the distance to remote and speakerphone max.10cm) press any buttons to the remote control.If you can hear the emitent signal in the speakerphone ,the remote is work.
4.Try the remote to TV.If work is OK,if not change the infra LED.
The solutions is work 100%,I tested 25 years ago.
Posted on Sep 07, 2009
REMOTE CONTROL IS INOPERABLE TO MY VIZIO 32 INCH FLAT SCREEN SERIES: E320B2
I assume you've replaced the batteries. Sometimes the remotes can go bad, especially if it's been dropped or had something spilled on it. I would suggest buying a cheap programmable remote control, and see if you can get it to work. If so, buy a new vizio remote off eBay. If you are unable to get any remote to work, it'll be the TV and will take far too long to troubleshoot over this chat. I hope that helps.
Jun 16, 2014 | Vizio L32 32 in. LCD HDTV
Vizio remote does not work
Yes, you can get replacement Vizio remotes at Walmart for like $10. I know you said you changed batteries, but were they new reputable batteries? Is it the OEM remote or a univeral remote you have?
Oct 18, 2012 | Vizio L32 32 in. LCD HDTV
My vizio tv starts scrolling through the inputs for no reason and wont stop
Hi
There are a number of things that can be checked.
Check the remote control sensor on the product and try again
Check if there is any obstacle between the product and the remote control
Check if the batteries are still working and are installed properly+to+ and-to-
Check if the appropriate input mode such as tv and vcr is set for using the remote control.
good luck
Kolbrun
Feb 25, 2012 | Vizio L32 32 in. LCD HDTV
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Older person cannot handle two remotes
You can program most satelite remotes to work on any device. Most are universal. If not, I suggest purchasing a universal remote. You can view remote codes online to program your device to your remote. New ones come with instrucions and codes.
Let me know how I can further assist you if necessary
Aug 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
Apr 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Mar 06, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
Jan 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Vizio VX32L Television Logo
524 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
