DP45SG won't POST / BOOT
PC with the DP45SG MB has worked from for a month, moved a week ago, it survived that just fine. Moved it to the other side of the room and tried to boot it back up, nothing. No beep, or post display. Cleared the CMOS and it booted back up went into Windows and worked fine. First time I had to reboot it failed to boot and no post again.
    Problem Solver:
  • 4 Answers
Go to the only resource on the web about the DP45SG. There you will find hundreds of users who will help you out:
http://www.abxzone.com/forums/f143/intel-dp45sg-skyburg-113330.html
Posted on Nov 24, 2009
    President:
  • 1,564 Answers
Unplug the unit, remove the battery and the cover for the harddrive then slide out the harddrive Wait for a few minutes and reassemble all parts. It should fire up.This could take a few tries, but it will eventually work. Another outside chance is to remove the cover for the processor and remove the heat sink from on top of the processor and wipe it clean where it contacts the heat sink, do the same to the underside of the heat sink.
Posted on Sep 07, 2009
We moved a week ago and just now plugged in the freezer and no power at all.It worked just fine before we moved
it is possible the freezer went into a defrost cycle leave it plugged in and in about 20 minutes it may come back on, or you may have a dead plugin . plug something else into the plug to make it is working
Jul 19, 2014 | Danby Freezers
Help, my Asus Essentio CG5290 won't post after moving.
check the cable for the bad monitor at BOTH ends. Some cables detach from BOTH ends, and if one side is lose, then you will get weird stuff happening....odd colors, lines etc.
Otherwise...it would seem to be a bad cable....which would **** if it is one of those that does NOT detach from both ends.....since you can't just go get another monitor cable.
Tallon41
Sep 16, 2012 | ASUS Essentio Computers & Internet
My ink cartridge won't move & is stuck on the right side. When I turn my printer on it tries to move back and forth like normal but only moves about a 1/4 inch and then moves back. It does this...
Mine did that before too! I just took the ink cartridge out and kinda wiggled it around a bit then replaced the cartridge and it worked! If that doesn't fix it I'd post the make and model of your computer so someone knowledgable could better help ya! Have a great day hope u get it goin!
Sep 21, 2011 | Computers & Internet
Respected Sir, I installed an nvidia 8400gs graphic card a year ago..........it works fine ....then two weeks ago i dusted up my cpu...........i inserted the graphic card then the computer...
it is because your nvidia card was broken, it makes the windows won't boot up, try to clean up your nvdia card (yellow circuit which will connect to the pci of the mother board) using a pencil eraser
i suggest you to change your nvdia card with a new one
May 14, 2011 | Dell Inspiron 6000 Notebook
Turn on laptop lights up no boot up monitor wont come on
it is very bad for a computer of any sort to sit for months even weeks at a time its just like a car engine sitting in the rain for that period of time and of course it will not work you may be having motherboard issues and you need to have someone that knows what their doing look at it for you! i hope that this helps!
Dec 19, 2009 | Acer Aspire 3680 Laptop
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Jan 28, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Blank copies
this does not sound normal. if he serviced it just a month ago is it under warranty? it is possable that the charge roller is not making good contact. or the mag roller is not turning. have the tech do a better job of explaining what fixes it.make sure the dev unit is engageing fully.
Mar 27, 2007 | Canon C180II Black and White Copier
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
