Question about Amana Refrigerators
The compressor is running but no air cirulating inside its a side by side
  • 10,515 Answers
You need to investigate in the folloeing order :-
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Posted on Sep 07, 2009
    How do i fix it so that it will collect water?
    1st ck that your humidistat is set correcly and unit cycles the compressor on/off correctly ,Not just the cirulation fan running all the time , next ck your filters , clogged up filters wont allow air to pull thru unit , also are you sure room has enough moisture in it to pull water from, Most units wont draw a percievable amount of water out of air thats got less than 52%rh , as most homes target a 70%rH as normal
    Dec 18, 2014 | Dehumidifiers
    My air conditioner is blowing warm air on the driver side and cold on the passenger side
    see this steps and think with clearly and logically NOT feared. God bless you
    checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
    If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
    If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
    If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
    If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
    If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
    Jul 24, 2012 | 2007 GMC Sierra Classic
    A/c not blowing cold air
    80lbs on the low side is WAY too much if the clutch is running, the high side you should see 125-150ish, the low 30-40. I would feel the lines (the bigger line going into the firewall to see if it is cold when your pressure is right) if so suspect a blend door motor which controls the hot and cold switching inside.
    Jul 24, 2010 | 1999 Chevrolet Venture
    The door frame of the refrigerator gets way too hot. the lady said it burnt her finger it was so hot. its a maytag msb2354grq
    It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
    Here's how to test the fan.
    http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
    Oct 21, 2009 | Maytag MSB2354G Side by Side Refrigerator
    My coleman mah 3 roof top will not blowon fan side
    Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
    Please rate solution
    Sep 09, 2009 | Coleman Mach III Air Conditioner
    Why does the air compressor still run with the air conditioner on even though there is no freon in the system? It cuts off normally when the system is turned off, but starts up again when turned back on. I...
    Why are you running the a/c with no freon. The compressor will run even if you have no freon because it has no way of knowing there is no freon sensor in any vehicle i know of.
    Jun 26, 2009 | 1995 Chrysler Cirrus
    Compressor not working warm fan inside frezer run
    Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
    Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    No cooling in freezer or fridge. Still running with lights on and air coming into freezer from vent inside freezer at the back but not cold air.  Kenmore Side by Side circa 2001 with ice and filtered...
    HI,
    if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
    thanks,
    Apr 26, 2009 | Kenmore 53642 / 53644 Side by Side...
    Not cooling
    hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
    Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
    Refrigerators Logo
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Steve
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
