Question about Garden
Troybilt model LTX 1842 riding mower: Engine won't turn over, even with jumper cables from car. Battery replaced two months ago.
  • A Miller May 11, 2010
    Does your starter run but not engage? There is the possibility you did in the starter motor with the car battery. I presume your tractor battery is in good shape?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Could be a lot of things i have one of these tractors and have all the common problems that go with it. #1 the blade engage leaver isnt puuled all the way to off position (worn or broken spring) #2 safty switch for brake or seat is either out of adjustment or flat out broke #3 my current problem with it is my ignition switch burnt up and deteriorated #4 the fuse on the side of the fuel tank is blown this is the min fuse for the whole tractor #5 your starter soleniode or starter itself took a ****.
hope this helps
danny98civic@aol.com
Posted on Sep 24, 2009
  • 279 Answers
Gotta be one of the safety switches. Get your manual and check all of them. If they are okay, check the starter solenoid. Good luck...Lee
Posted on Sep 09, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Riding troybilt mower, with Koehler engine. Engine just clicks when turning key. You can hear the clicking noise behind seat near the solenoid
It is most likely the battery, check the cables for tightness and corrosion. Correct either of the problems and make sure you have at least 11 volts in the battery. If it is lower, you need to charge or jump the battery. Also make sure the battery ground wire is clean on both ends.
Jun 06, 2016 | Garden
How to wire solenoid on Troy Bilt ltx 1842
Didn't specify solenoid of the two so is a link to the wiring diagram.
http://c.searspartsdirect.com/lis_png/PLDM/P0401171-00010.png
Oct 29, 2014 | Garden
Need to put a new belt on the rear of the Troy-Bilt LTX 1842
First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Wizard riding mower won't start.
with jumper cables jump from the battery direct to the starter if ok sounds like the safety switch on the brake pedal is bad
Apr 27, 2012 | Garden
My Cub Cadet LTX 1040, has no power to anything and will not start
check the battery cables bypass them with your jumper cables the check the safety switches
Apr 12, 2012 | Garden
ENGINE WILL NOT TURN OVER, EVEN WITH A FULL BATTERY CHARGE AND JUMPER CABLES. THE STATER ENGAGES AND THE FLYWHELL TURNS ABOUT 1/4 REV. AND STOPS. IF I MANUALLY ROTATE THE ENGINE MORE THAN 1/4 TURN (PAST...
I am betting you will not believe this, but, your battery is bad. I just had the same problem last month. Same, same. I have always had good luck with jumper cables, but there was something wrong with the mower battery. When I removed it and replaced with new one, everything is as new.
May 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Bad battery or starter
Hook a known good battery out of another vehicle or take the leads off of your mower battery and hook a set of jumper cables from your car battery and see if it turns over hard still. Does the mower run good once started or does it not start at all because of the slow starting?
Sep 08, 2009 | Ariens 34 In. Zoom Series Riding Mower
Troybilt riding lawnmower - won't start
i have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Snapper riding lawn mower won't start
my snapper riding mower will spin but will not start. It was o.k. when I parked it a week ago. Now it won't start 28115BV
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
1,388 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
