Question about Kitchen Appliances - Others
Installation instructions for sensor light model
Cannot find installation instructions for outdoor sensor light model SL 6012RX. Has a wireless motion sensor. Have Light base wired to wiring, switch is on and cannot get to light up from motion.
3 piece package, wireless mountable sesnsor, light base with wires, and a small box tha tplugs in to wall outlet in house which relays a beepor alarm sound when motion sensor is activated.
SOURCE: Heath Zenith #SL-5316 Motion detector light what are settings?
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
Posted on Jun 16, 2009
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
kermit854
  • 38 Answers
SOURCE: 120 volt folorescent light sign with a photocell
Based on what you've written, it should be black to red, white to white, and green to green. If you still have trouble, post a picture so I can have a better look of this photo-cell.
Hope this helps,
Kermit
Posted on Aug 22, 2008
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Posted on May 05, 2009
  • 13 Answers
SOURCE: is there a ac outlet dimmer that i can use on my
As far as I know no one makes an AC outlet power dimmer because it is unsafe and you do not know what someone may plug into that thing if it were available, which could be a fire hazard and the reason it is not made in the first place.
But to answer your question, yes it is possible to use a dimmer on halogen lamps, and in fact they last longer when dimmed slightly.
Posted on Aug 27, 2009
Lights flash on/off non-stop, until reset, then does it again. model SL-5408 GR-B
Have you reset the controls on the sensor itself. Suggest you reinstate factory settings and start over.
Hope this helps.
Aug 31, 2013 | Heath Zenith SL-5318-WH Dual Brite Motion...
Instructions to wire a cooper light model number MS35 rain tight
1) Copy following link for wiring diagram of 2-light outdoor motion sensor.
http://waterheatertimer.org/How-to-wire-switches.html#motion
2) Existing light fixture will have 2 wires: Connect wiring as shown on link above, then keep light switch turned ON.
Jan 21, 2013 | Hardware & Accessories
My Motion detector #5512 quit working after we had our house washed. One bulb was out so I replaced that. Both bulbs glow but do not turn on.
Reset circuit breaker.
Check if you are on a GFCI circuit.
Probably there is no hope, but the sensor has to be removed to replaced, so take it off and hang it upside down and let dry in sun.
There is no repair protocol for fixing motion detectors, because there are no replaceable parts, or circuit boards.
Cover outdoor electronics with plastic bag when washing house. That includes light and pool timers, breaker boxes, low voltage timers, infrared cameras, motion detectors, alarm boxes, etc.
Should the power wash contractor know this? Maybe yes.
We never covered things when washing houses, and we washed 100s per year, but I told the guys not to put pressured water directly on any outdoor electrical system.
Can you prove that the sensor stopped because of washing. No.
The unit could have simply stopped working.earlier that morning, without provocation.
Jul 16, 2012 | Heath Zenith SL-6136-WH Basic Solutions...
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
LED motion sensor lamp, after installed, does not turn off, it is on all day long
usually motion sensor led lamp is a little different from general led lamp. the work condition will shift from general lighting to motion sensor light. The reason why installed, but can not turn off, might you install in the wrong way. You can see the installation details Pir Sensor Led Tube 4ft f328a61c-a223-4610-b54f-1ba4836154f7.jpg
May 28, 2012 | Home Security
I have motion lightts on my back porch. I would like to just plain turn them on when I have a back yard party, but I don't know how to over ride the motion sensor. Can you help? Thanks.
On most motion sensor lights if you turn the switch on, then off and on quickly, they will stay on till you turn them back off. Leave it off for at least 10 seconds and turn it back on to go back to the motion sensor.
Sep 06, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
Outdoor sensor won't work
Hi, Remove the cover and check for power. If you have power,replace it.No power, look for a tripped breaker. Good Luck,
Shastalaker7
Nov 14, 2009 | Heath Zenith SL-6106-IV Motion Sensing...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Kitchen Appliances - Others Logo
124 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
