Question about Nokia 6500 Slide Cellular Phone
There is problem with the reminder alarm - Nokia 6500 Slide Cellular Phone
I tried to set a reminder and it said it was set but I didn't get the reminder. I can delete the reminders but it simply will not remind me. What is the fix?
This question needs elaboration in order to get the desired answer. We don't know if the alarm was set on PC, Laptop, Mac, Chrome book, iPhone or Android Pjone. I will still try as little/much as I can. I want to assume you're taking about phone here. I encountered the same problem on my Android phone sometime ago. I always saw "missed alarm" at the end. The problem wasn't the phone but me. I didn't remember that alarm has different volume setting just as media and notification have their differnt volume sittings. I didn't realise that alarm volume was set to zero while media and notification volumes were at normal level. This may be your case also. Just go back to your phone settings and verify the alarm volume level. Good Lick.
Dec 27, 2017 | Cell Phones
GE profile microwave keeps alarming "reminder"
test this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2ZpM2PvPs
Jul 22, 2013 | GE Microwave Ovens
GE Spacesave microwave won't work. Display says REM. What does that mean?
"REM" is "reminder". That's covered in your owner's manual.
Here's a sample:
"The Reminder feature can
be used like an alarm clock
and can be used at any
time, even when the oven
is operating. The
Reminder time can be set
up to 24 hours later.
1 Press REMINDER.
2 Enter the time you want
the oven to remind you.
(Be sure the microwave
clock shows the correct
time of day.)
3 Select AM or PM.
4 Press REMINDER. When
Reminder signal occurs,
press REMINDER to turn
it off. The Reminder
time may be displayed by
pressing REMINDER.
NOTE: The REM indicator
will remain lit to show that
the Reminder is set. To
clear the Reminder before
it occurs, press
REMINDER, then 0. The
REM indicator will no
longer be lit."
Jan 27, 2011 | GE Microwave Ovens
My htc touch reminders won't sound. The general alarm works but not the reminder alarms in the calendar, texts, e-mail, missed calls etc all sound, just not the calendar reminders
From what I have already experienced so far, some WM6 builds seem to be prone to have their notifications queue messed up.
Google for 'checknotifications_arm.cab', intall it on your device, and tap on 'Options > Settings...', tick both checkboxes there. Tap ok,' and 'Clear', at the top of the application's screen. Your notifications queue will be free of garbage, now.
Then, go to your Calendar application, choose a day which has the next events with notifications (reminders), Edit each one of them twice: one to delete the Reminder settings, and another one to reset them (you'll notice that at the 2nd edititing action for each event, the Reminder settings will be shown as they were, prior to their deletion - less work to be done!). This will set Calendar entries in the notifications queue.
Your reminders should work from now on.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 12, 2010 | HTC Touch P3450 Smartphone
I have a 1999 Olds Intrigue, headlight left on alarm is stuck
The Body Control Module (BCM) controls the audible warnings. Refer to Body Control System Description in Body Control System for more information regarding the BCM.
The body control module (BCM) controls these reminders:
• Key in ignition reminder: An audible warning intended to remind the driver that the key has been left in the ignition cylinder. The BCM sounds the chime for this reminder at a rate of 150 chimes per minute.
• Fasten seat belt reminder: An audible warning intended to remind the driver at the beginning of the driving cycle that the driver's seat belt is unfastened. The BCM sounds the chime for this reminder at a rate of 50 chimes per minute.
• Fasten belts indicator control: A visual warning intended to remind the driver that the driver's seat belt is unfastened.
• Parking brake reminder: An audible warning intended to remind the driver that the parking brake has been left applied with the transaxle shifted out of PARK. The BCM sounds the chime for his reminder at a rate of 200 chimes per minute.
• Turn signal reminder:
An audible warning intended to remind the driver that the turn signal has been left on while the vehicle has traveled over 1.2 km (¾ mile). The BCM sounds the chime for this reminder at a variable rate (in unison with the turn lamps on) of 90 chimes per minute.
• Headlamps ON reminder: An audible waring intended to remind the driver that the headlamps have been left on. The BCM sounds the chime for this reminder at a rate of 200 chimes per minute.
• Last door closed locking confirmation: An audible warning intended to provide the driver feedback that the last door closed locking feature is active. The BCM sounds the chime for this remainder at a rate of 200 chimes per minute.
• Feature customization and diagnostics feedback: An audible feedback used when changing feature customization modes. Also used by service technicians during the BCM diagnostics. The BCM sounds the chime during the feature customization, and also during diagnostics. Refer to Body Control Module (BCM) for additional information.
Step
Action
Value(s)
Yes
No
Was the BCM diagnostic system check performed?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Body Control System in Body Control System
Check for Powertrain Control Module (PCM) Diagnostic Trouble Codes (DTCs). Refer to Powertrain On Board Diagnostic (OBD) System Check (LX5) or Powertrain On Board Diagnostic (OBD) System Check (L36) in Engine Controls for more information.
Are there any PCM DTCs present?
Go to Appropriate DTC Table in Engine Controls
Go to Step 3
Connect a scan tool to the Data Link Connector (DLC).
Using scan tool, select BCM data display inputs and monitor the park brake switch input.
While observing the scan tool, apply and then release the park brake.
Does the scan tool indicate that the park brake input is off while the park brake is released?
Go to Step 7
Go to Step 4
Turn the ignition switch off.
Disconnect the scan tool from the DLC.
Disconnect the BCM connector C1.
Release the park brake.
Using a test light, connect between B+ and the BCM connector C1 terminal D5.
Is the test light off?
Go to Step 7
Go to Step 5
Your best bet ,take it to a qualified repair shop
Aug 01, 2017 | 1998 Chevrolet S-10 Pickup
Need a alarm clocl on it or were is it?
Try using Datebook, it isn't exactly an alarm but you can program reminders and apply them daily, work days, multimple days (allowing you to choose which days you want to be reminded), weekly, day per month, or even yearly.
Apr 19, 2009 | Motorola Mobility I335 Cellular Phone
Alarm clock
Mar 25, 2009 | Motorola Mobility I335 Cellular Phone
Calendar reminder or alarm
no they wont, system is shut, hardly any activity is in action
Feb 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
How to set an alarm for a date in the future
When you set it,
did you tick the little box that says ALARM ??
Feb 06, 2008 | Samsung SGH-U600
Is an audible alarm software available?
I'm not sure of the HX4705's capabilities to sound multiple alarms, but I have downloaded a free alarm program called Wolfclock to my iPaq rz3715 which I use for the exact same reasons (meetings, wake up, take medication...) Try this link: http://www.pocketpcfreewares.com/en/index.php?soft=1045
Sep 14, 2005 | HP iPAQ HX4705 Pocket PC
Nokia 6500 Slide Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
