Question about Car Audio & Video
I have an in car entertainment monitor, toad m3 lcd 681rt that appears to be frozen, the manual says there is a reset button but doesnt say where!!!!!!!! can you help , worked the last time i used it , has input and power but just a white lined frozen screen. this is factory fitted in a Honda CRV 2004.
bbtoast
  • 319 Answers
SOURCE: Honda CRV 2002
Hi Ed
Please see the following article posted here.
It explains where to find the code on your vehicle. It is on a white sticker "somewhere" in or on your vehicle. This could be as simple as the glovebox door, to the engine compartment to the inside of the center console.
It is a 5 digit code.
Good Luck
Brian
Posted on Jan 10, 2008
SOURCE: HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Posted on Sep 08, 2008
freetek
  • 5568 Answers
SOURCE: Lcd monitor 20.1
The white screen is caused by a total lack of control over all pixels. The opposite effect; all black, happens when a failure turns all pixels on, blocking all but a small amount of light.
This could have more than one source; one output of the power supply has failed so the logic section no longer is receiving supply voltage or an external source has damaged the video input of the monitor. The backlight responsible for the white screen is obviously working as this is a separate power supply output to an inverter that powers the backlight lamp.  I'm afraid this is not a DIY repair.
Posted on Sep 18, 2008
  • 38 Answers
SOURCE: White Screen on Dynex LCD
Please stop buying these cheap things.....your out of luck. Parts are not available for these cheap chinnese sets....Thank Bill Clinton. Anyway, sound like the tuner going out. But....you can't get a tuner...Sorry. Just try using a vcr or cable box on video input and change channels that way.
Posted on Dec 05, 2008
SOURCE: 2002 Honda CRV. radio CD - CODE
I own a 2002 Honda CRV. I bought it used and all owners manual was provided with the purchase. I lost power to the car's system and the radio set itself in an anti-theft mode requiring a code to get the radio to function again. I tried pushing several buttons without succees.
I need your help to put the right code!!
Posted on Mar 16, 2010
HP L1720 monitor on screen control frozen in center of screen
mcdevito75 here, Try to simply shut the monitor off at the monitor itself, Or with your computer shut down, disconnect and reconnect the monitor to the computer.
Jul 10, 2010 | LG 22" FLATRON LCD Monitor
There is no picture on my LCD monitor
try other connector on graphics card, or switching source(you will find it in user manual, probably by pressing source button on monitor)
Jul 10, 2009 | Dell SE198WFP LCD Monitor
OSD Menu on my montior is lock on a Balance CM2017 LCD monitor i cant change any of my menu opitions....HELP
The answer depends on your monitor model, of course.
For some of the LCD models you may reset the monitor by pressing (and releasing) the "MENU" button (OSD menu appears) then hold the "SOURCE" button for a few seconds. When you see the monitor blinks it means that reset was done.
Apr 20, 2009 | Computers & Internet
I had my 2003 BMW M3 in for it's annual oil change and they didn't reset my oil change maintanence light. It is still showing 3700 miles before next oil change and I just got it done.
1. Key in 0 or off position.
2. Press and hold odometer button and turn key to 1 or acc. position... like you're turning the car on, but don't crank the engine.
3. Keep button pressed until any of the following words appear in display: "oil service" or "inspection", with "reset" or "re". For vehicles with "high cluster", the fuel amount (in litres) remaining until next service is displayed (i.e. 3224).
4. Press and hold button again until "reset" or "re" flash.
5. While display is flashing, press button briefly to reset service interval indicator. After display has shown new interval, the following will appear in display for approx. 2 seconds:"END SIA"
Apr 14, 2009 | 2003 BMW M3
Color calibration Envision 17" monitor
Return to dealer for service, This is a common problem of a bad backlight on LCD Monitors. If it is on the top comming down it is the top lamp,from bottom up is the bottom lamp. Hope this helps you .
Dec 17, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Ipod touch frozen on Itune connection
Per the first Google result for "reset ipod touch", http://www.mydigitallife.info/2007/10/04/how-to-reset-iphone-and-ipod-touch-hard-reset-or-reboot/ says:
"Press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done"
Nov 22, 2008 | Apple iPod touch
Vertical positioning setting is frozen
lets see what i can do
sometimes under the screen edge either side or bottom they have the menu buttons these have become hard to find but there on your screen on one of the buttons the select should be de gaus (spell check) this sends a powerful power signal to monitor to reset its self some times its scary to watch but when it does that it should release the buttons parameters back to working state then use the buttons to set your parameters
the other thing is there is something stuck or broke in the button which was pushed a little harder then most
if this is the case
and you dont want to mess with monitor then take to computer tech. they will tear down and replace button backing sometimes the button backing points break off or disalign do to tomuch preasure on the button
i hope this helped you
May 25, 2008 | Acer AL1715 17" LCD Monitor
My Saamsung M3 YP K5 has frozen and refuses to operate - frozen
im havin the same problem my ones worse when i turn it on its frozen all i can see is white the menu doesnt appear can anyone help me fanks
Feb 11, 2008 | Samsung YP-K5 MP3 Player
TOAD CAR ALARM RECODE
under the steering wheel you see the car alarm has a brain and ared and black wire remove the fuse on the red wire it will kill the alarm and you can start up your car
Feb 06, 2008 | Car Audio & Video
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
