Question about Dryers
DRYER WILL NOT HEAT UP ELEMENT TURNS ON THEN OFF
    President:
  • 1,922 Answers
Your hi-limit switch is defective on the element case
Posted on Sep 20, 2009
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
Turns but no heat
sounds like your heat element needs replacing, just happened to a close friend, turns out she didn't have the lint duct properly attached for proper ventilation, burned out "heat element
Dec 17, 2010 | Dryers
Barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Apr 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer won't heat
The first thing to check would be the power, I know that sounds silly since the drum turns but your electric dryer uses 240 volts to heat and only 120 to run the drum. Check the circuit breaker or fuse by turning it off completely then back on.
If that does not fix the problem you have one of two components that have failed. Either the thermal cutoff or the heating element. The cut off is a small two wire heat sensing switch located just above the heat element. They are both accessible from the back
Apr 23, 2010 | Whirlpool LER5636P Electric Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
The dryer turns but no heat.
sounds let the heat element inside the dryer is burnt out or a sensor or door switch.
Dec 13, 2009 | Dryers
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
