Question about Samsung Cameras
Even though my camera is on charge, it won't turn on and makes the no battery noise. its been charging for an hour
    President:
  • 2,761 Answers
It may be something more serious, or your new batteries may be worn out to the point that they won't accept a charge, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Posted on Sep 07, 2009
Camera wont turn on after charging the battery
Bruce, you didn't provide a lot of information but I can tell you that the few times this has ever happened on my Nikon D-90, the battery did not charge, would not charge and I had to throw it away, or it was a charger problem.
I've had it happen when I tried to charge it on my corded Nikon Charger and I never got a charging complete indication after charging over night. When I put it in the camera, the camera indicated it was not charged even though the charger indicated it was charging. But, when I put it on a travel charger, it charged in about an hour and worked fine. The next time I put it on the Nikon charger, it worked fine.
I suggest you verify that the battery is good and charged or capable of charging. If it is, then check to make sure the battery contacts are clean both on the battery and in the camera.
If the contacts are clean and you're sure the battery is good and charged, I'd say the next step is to contact Canon. I've heard their customer service is very good.
May 20, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
My LG 4G LTE won't turn on even though it has been charging for hours.
do you have a universal travel charger? and use it to charge your battery for about 4 hours. or buy a new battery.If it is not ok, your phone is in short-circuit. go to service center
Apr 15, 2013 | LG Cell Phones
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
For fully charged NI Mi batteries 2700mA, when I turn on my camera I may or may not get the red low battery sign, I may or may not get over 15 shots, and I end up to the "instruction" that my...
how much time between shots is it? ususally there is a 3 minute none use shut down timer or warning light. so if it is more than 3 minutes from the time you take one picture to the next picture then that might be your problem. also these new digital cameras have all kinds of sensors built into them now. they have motion and face and distance and light and image sensors in them that use your battery. also the new 3d digital cameras have even more sensors. the memory card also uses the battery as well but you digital camera won't work without it though. some flashes add-ons may you the battery. almost forgot about the lens, they also use the battery as well. the use it in the "auto focus" and with the power zooming. so if you are moving around allot and zooming the focus in/out allot then this uses the battery as well. try to do as many shots as you can in three minutes as you can then power off the camera and when not in use this may extend the battery life.
also chargers have a 12 to 24 hour charge time while others are fast chargers and may only have a few hours of charge time called quick chargers. some chargers have lights that indicate charge or charge complete see your charger's user's guide for this.
also check the contacts on the battery itself and make sure that they are clean and shiny because dirty contacts leads to not working well or charging properly.
Aug 25, 2011 | Canon PowerShot A570 IS Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Camera will not turn on even though battery is charged
thanks
Apr 21, 2011 | Cameras
My camera won't turn on even though it's fully charged
Is there no sign of any light from the camera when you turn it on? When was the last time you used that camera? If you have left the battery inside the camera for quite some time, then most probably, it got exhausted. Despite of being charged for hours, can you put back to the charger again and see if it gives a red battery charging indicator? If it gives a red light, then you may need to replace the battery pack.
Hope this helps. Thank you for using FixYa.
Dec 20, 2010 | Olympus FE-370 Digital Camera
Cameras Logo
56 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
