Question about Jandy Laars Lx Heater 250btu, Natural Gas Low Nox
ES 1 light coming on on control panel. What is it
ES 1 light coming on on control panel. Heater won't fire. What is it and how do I fix it? Thanks
    Champion:
  • 246 Answers
The fusable link is open need to be replace, the reason is bad is the burners are plug need to be clean
Posted on Sep 13, 2009
Karcher hds750 pressure washer. The heater won’t fire. heater won't fire.
ok ok the heater won't fire. ya burnt the element out that why it won't fire, get used to cold washes or get it fixed.
Jan 06, 2018 | Karcher Garden
The air is warm coming out of the passenger side vents and cool out of the driver side vents,But the temperature button won't increase the temperature. Seems stuck on Max Cold
it's dead, jim. time for a troubleshoot and repair. These toyotas are notorious for climate control problems. Either your control panel is broken, or the electronic air blend motor is broken, or some plastic in between. 25315509-zejmo41uy3tce5x43qikgza0-5-0.gif
Dec 10, 2014 | 2004 Lexus RX 330
Hurlcon spa heater won't ignite
I have a hurlcon mini max 120 spa heater Same type of problem. If you can't hear the relay click when you turn it on......your control board is faulty even if all the lights on ie power, flow, heat... The power for the igniter and gas valve is the orange wire coming out of the control board. if you test this with a test light (24volt) it should light up if not check power coming in. if it has power replace control board or get some guru to fix it. hope this helps
Jul 28, 2012 | Pool & Spa
Need help finding inlet heater hose from fire wall to engine
The inlet going TO the heater core should be the top one (I think) but in any case it would be the one with the heater control valve on it (see picture below) Hope this is what you were looking for....
Mar 05, 2012 | 1998 Lexus ES 300
I have a Pentair Minimax NT 250k electronic heater. Turned the heater on today and it does not get through startup sequence. It flashes - - -, then flashes 888 (with red service light), then back to - -...
I would say the problem is the thermistor. The board will light up, the SW switch is green, but you get a display that flashes dashed lines and then what looks like 888. That is a start up code. The thermistor is located on the side where the water enters the heater. There are two screws at the top of the side panel. Undo the screws and lift the panel off. The thermistor is a probe with 2 small wires coming out and lead to the control panel. It is a very simple fix and is usually the problem if you have not experienced any other issues. The part runs between 30 and 45 dollars. Most pool stores would carry this.
thanks let me know if that fixed the problem
May 21, 2011 | Pentair Minimax NT Heater
Fan blows, but heater display doesn't light up. blows out cold air only. no heat
Check fuses to the A/C or Heater Control Unit in the fuse box(es). IF none are blown, then may have to replace A/C-Heater Control Unit:
A/C-Heater Control Unit Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Center bezel from the instrument panel A/C-Heater Control chr_pacif_ac_htr_cntrl.gif
    • Three screws that secure the A/C-heater control to the instrument panel
    • A/C-heater control from the instrument panel
    • Two wire harness connectors from the control
To Install:
  1. Install or connect the following:
    • A/C-heater control to the instrument panel
    • Two wire harness connectors to the back of the A/C-heater control
    • A/C-heater control into the instrument panel
      1. Torque to: 17 inch lbs. (2 Nm)
    • Negative battery cable and calibrate the A/C-heater control
Nov 06, 2010 | 2005 Chrysler Pacifica
Passenger seat heater light come on but no heat on 1997 lexus es 300
You wanted to charge me to tell me how I fixed The Problem and, now you are asking me how I fixed it . IF you tell me how you would have fixed it for free I'll tell you what I did for no cost. Thank you.
Dec 16, 2009 | 1997 Lexus ES 300
Jandy Laars Lx Heater 250btu, Natural Gas Low Nox Logo
65 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
