The Panasonic system your DT phone plugs into has a master phone (usually extension 101). At the very minimum, it can change the system time. You also have the ability to let incoming phone calls set the system time If your minutes and date is correct and only the hour is wrong, then you probably have a CID offset problem from your connected phone lines or a DST to Standard time correction.
The time setting sequence is in the Operating Manual (OM) for your system and is usually Program **1234 and dial 000.
Why does the date and time change automatically after I have programmed the date and time on my phone?
If you are subscribed to Caller ID from your phone company, the unit's date and time setting will be automatically adjusted when caller information is received. If you do not wish for this feature to work, press [MENU][#][2][2][6] on the handset, then press [0] to select "Manual" and press [SAVE]
With handset down on main phone Press ‘Program’ Dial ‘**0000’ or ‘**1234’ (system program no) Dial ‘#000’ Press ‘Next’ Enter the date using the dial pad Press ‘Next’ Enter the time using the dial pad Press ’Store’ Press ‘Program
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.: From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook: 1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234). 2. Now press 000 and then ENTER. 3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE. 4. Scroll right with the right arrow key and change the date. 5. Press the NEXT button on the screen and the time will appear. 6. Set the time. Press AUTO DIAL / STORE to save your changes. 7. Lift the handset and put it down to exit program mode.
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 000 and then ENTER. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE. Now scroll right with the right arrow key and change the date. Now press the NEXT button on the screen and the time will appear. Set the time. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode. PLEASE rate/vote this answer if it was helpfull. THANK YOU
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101. 1. leave handset in the cradle then press "program". 2. Dial *# then "SP-PHONE" button until you see something like time set something something 3. manually input correct date then time then press "auto dial/store" button. 4. pick up the handset then hang up to save.
5. Programming
The Getting Started Guide gives clear instructions as to basic programming via a KX-T7730 system-phone. To enter the program mode with a KX-T7730 simply press the programme button followed by * # and your password. However, one of the interesting aspects of this system is the ability to use a PC to configure the system. Windows based software is supplied with the system. You simply load the software and connect to your PC via a USB port. The USB lead is not supplied with the system.
