Question about Hitachi 43FDX20B 43" Rear Projection Television
Black mini screen in the middle of screen...
There's a black mini screen in the middle of my screen on certain channels and it's not coming off untill I turn it off and on it stays good for a few minutes then it happens again. What's happening?
  • 934 Answers
Go to the closed caption menue and turn off "text"... That's a text box and in most areas there is no feed so the black box is all you'll get...
Bill
Posted on Dec 09, 2007
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
Replaced TY-LA1000 Lamp and now a black box across the picture, TV is PT-50LC14
Check in main menu (set and box if using one) under closed captions--one of the settings is TEXT--black box will appear in middle of screen and certain channels--with the remote turn text off.
Apr 05, 2012 | Panasonic Televison & Video
There appears a black box on screens on certain channels
Hi, hit the cc button on your remote control untill the close caption display says off, this should eliminate the box from your screen
May 19, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Black box fills most of screen on certain channels
THE cc key on your remote control might of been pressed by accident and the close caption was enabled, to correct this all you need to do is press the cc key repeatedly untill the c.c. is turned off, the tv display will go through cc1, cc2, txt1 etc. untill you get to the part that says cc off.
Jan 31, 2010 | Element Electronics FLX3210 32 in. LCD TV
Having a black screen in the middle of the picture only on a certain channel
Go into the customer menu and select closed captions--there will be an option for CC1 etc--box in middle of the screen means somehow TEXT 1 WAS SELECTED--the idea here was they would have books or written material on certain programs like PBS--select once that you find TEXT is highlighted or select OFF or something else other than TEXT.
Very common problem on a lot of sets---it only appears on some channels because not many ever offered it for use.
If this helps you rate this solution as I do this here for FREE.
SD TECH.
Nov 11, 2009 | Televison & Video
RCA F26051EM TV menu text is black in a black window can't readto make adjustments
go into menu and look for Closed caption---one of the items will be TEXT---if it is engaged you will have a black box on certain channels in the middle of the screen---switch the text to CC1 for closed captions
Aug 06, 2009 | Televison & Video
''big black box that appears in the middle of the screen on certain channels''
It's your "closed captioning." Just turn that feature off, and you'll be good to go!
Jun 12, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Black square box pops up in the middle of tv screen.
turn off the closed captions - you have it in text mode that will have a big black box with video on the sides
thanks
scott
Feb 14, 2009 | Polaroid LCD-1700 17 in. Television
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Hitachi 43FDX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
