Question about Canon PowerShot A530 Digital Camera
The camera turns on and seems to operate normally but the lcd display is black and the pictures are black. If I review older picures the lcd display is fine.
    President:
  • 1,564 Answers
Time to clean the battery slot. Take a Q-Tip "dampened" in rubbing alcohol and clean the battery contacts within the compartment. Be careful not to snag the small battery ejection spring toward the outer edge. It a good idea to wear a magnifying headset while doing this. Do the same to the battery and the charging station.
Posted on Sep 07, 2009
My cameras screen has gone black and will not turn on. All other aspects of camera seem to work. If I take a photo, will they be saved onto the memory card as normal or will the photos be black?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Thank You for using fixya
Sep 21, 2011 | Olympus Stylus 790SW Digital Camera
Sanyo vpc-s120 12.1 megapixel digital camera the lcd screen has a dot on it. can anyone help me!!
Seems to be a common problem... walmart.com reviews show a few people having the same problem and after only owning this camera for 3 weeks, it is doing the same thing to me. I'm taking mine back for a refund tomorrow.
Aug 15, 2010 | Sanyo Cameras
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
I took pictures from my nikon d40x but all photos are displayed black in lcd. Would you know how to fix this error?
If your LCD screen works normally as a viewfinder and lets you review photos then your shutter is likely stuck in the closed position. If the display is black in all modes your LCD display is bad. Unfortunately, there is no safe DIY fix for either problem. The camera will require professional repair.
Nov 15, 2009 | Nikon D40x Digital Camera
When I turn my camera on, the lcd doesn't display. I can review an image though in the play mode. any ideas??
Rebel XT doesn’t have live view function. You cannot have picture on LCD when taking picture. If you can review the pictures and operate menu on LCD, your camera just fine.
Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
LCD Display
As far as I am aware, the 400D doesn't have a live preview mode.
What you are describing is perfectly normal and is how 99% of digital SLR cameras behave.
Are you sure it used to do this?
Matt
Feb 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Canon PowerShot A530 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
