Question about Lexmark Z2300 InkJet Printer
Lexmark Z2320 - Will not print Colour
Lexmark Z2320 - Will not print Test Page or any page in colour- fitted with new B/W and colour cartridges, however will only print in B/W, settings in Print Set Up are OK, any ideas? I have tried new cartridges, power on/off etc.
  • info95649 Sep 08, 2009
    I'm assuming the print head is the cartridge, this has been replaced twice, for some reason I suspect the problem is software related because when I print a colour test page the colour parts are replaced by black print - ie. there is no missing print, similarly if I print a word doc - what I would expect to see in colour is printed in black - any ideas? Brian
    President:
  • 1,124 Answers
You could try to un-install the printer and re-install it - if you have the cd.. This sometimes will clear up problems in communications between the printer and the computer..
If that does not work - it could be a problem with the cartridge carriage or possibly another component that is failing..
Also check the manual for trouble shooting..
Maybe check here - http://www.lexmark.com/lexmark/product/home/36/0,6970,204816596_653399455_1189434404_en,00.html?tabId=1
for service help and trouble shooting..
Good luck...
Posted on Sep 08, 2009
  • Lexmark Master
  • 19,396 Answers
The colour print head is probably clogged. You can try cleaning the printheads.
First try using the clean nozzle/heads option on printer utilities , do it a couple of times.
That probably won't work.
Try soaking the printheads in isopropyl alcohol solution for one day or so.
If that still does not work, then the printhead must be replaced.
Posted on Sep 07, 2009
How to reset ink memory z2320
Here are my initial thoughts:
A. Press 'Order Ink' and continue according to manual without actually ordering ink. At the end of this process, you may have fooled your printer to think that you placed new cartridge. If this is not possible, then your ink station is not very good, they did not reset your cartridge even though it was necessary for your model.
B.
1. Turn the printer off;
2. Enter the Diagnostics Mode by holding down the GO and RETURN buttons while powering on the printer until the display reads PERFORMING SELF TEST. When ready, the display will read PRINT REGISTRATION;
3. Scroll to PRINTER SETUP and press the SELECT button;
4. Scroll to MAINTENANCE PAGE COUNT and press the SELECT button;
5. Scroll to RESET MAINTENANCE COUNT and press the SELECT button to reset the count to zero
6. Press the RETURN button to return to the Diagnostics Mode main menu, then exit Diagnostics Mode to return to normal mode.
C. Use The Printer Solution Center Option
  • Open the "Printer Solution Center" program on the computer associated with the Lexmark printer.
  • Select the "Maintenance" tab in the "Printer Solution Center."
  • Select the "Install a new printer cartridge" option.
  1. Click the "Next" buttons until the "Print the Alignment page" window appears onscreen.
  2. Select the "Print" button. If the Lexmark printer still doesn't read the refilled cartridges as having sufficient ink, repeat the process.
Resetting the Cartridge Option
  • Remove the black and color cartridges, refilled or new, from the printer.
  • Turn the printer off using the power button. Leave the printer off for about 20 seconds to allow it to power down completely.
  • Turn the printer on using the power button. The printer will go through the normal start-up process and will determine that no cartridges are installed.
  • Repeat Steps 3 and 4 five times. This process will allow the Lexmark printer to remove the usual five most recent ink cartridges from its memory and list of current ink cartridges and, as a result, accept the newly refilled ink cartridge.
You might find the following video link helpful:
May 01, 2012 | Lexmark Z2320 InkJet Printer
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
Colour setup for x4650
Make sure the color ink level is substantial for printing, otherwise, replace it with a new cartridge. Try to clean the cartridge nozzle - from the printer operator panel, press the Setup button > Maintenance > Clean Cartridge > press OK. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Then try to print your file again to verify that the print quality has improved.
Nov 10, 2011 | Lexmark X4650 InkJet Printer
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have a lexmark z2320 inkjet printer the colour cartridge is empty should it still print the black is full
I'm not a computer geek at all, but I find the color cartridges always run out first. Try to change your printer settings so it will only print in black and white and so uses the black cartridge and not the color one. If the the color cartridge is empty, the page will not print correctly. It may print some of the black color only.
Mar 26, 2011 | Lexmark Z2320 InkJet Printer
Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Oct 07, 2008 | Lexmark Z515M InkJet Printer
All in one printer fault
Pull the cartridge check to make sure you removed the seal. Take a damp cloth gently wipe across the ink openings. If you get ink reinstall. Go to printer settings and make sure you are not set on documents black and white but on colour printing. Go to maintainance run test page several times. hope this works for you.
Sep 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 3200 colour printer
Dear friend There may be serious problem in the printers mother board which is not sending any signals for the bklack cartridge and should be diagnosed. Pran
Jan 21, 2007 | Lexmark Color JetPrinter 3200 InkJet
Lexmark Z2300 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
