Question about Speed Queen Washing Machines
How do you remove the agitator on a speed
How do you remove the agitator on a speed queen model awm593w/l2
  • 156 Answers
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Posted on Feb 25, 2008
SOURCE: Speed Queen doesn't agitate.
can i see solution that ziobob got on nov.08 2008
Posted on Dec 02, 2008
defadad
  • 351 Answers
SOURCE: commercial speed queen won't agitate
sounds like it is in the gearbox, possible broken gear
Posted on May 27, 2009
SOURCE: How do I remove the agitator on my Speed Queen
I just did that. Just pull up really hard. Now.. how to get that other thing off to pull the tub, I can't figure out, all bolts are removed.
Posted on Sep 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: i have a speed queen washing machine for 10 years
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
How do I remove the agitator on a speed queen washer model # aws17nw
It has a large nut under the cap on the top of the agitator, but it will be the devil to remove due to a tight fit and corrosion.
Sep 28, 2016 | Speed Queen Washing Machines
How to remove agitator on Speed Queen model LWS21Nw
Go to www.repairclinic.com and enter LWS21Nw. You will be presented with a list of common replacement parts and may be able to view a general video showing disassembly.
Jul 20, 2016 | Speed Queen Washing Machines
HOW DO I PULL AGITATOR ON A SPEED QUEEN WASHING MACHINE MODEL AWS76NW
down the center about 6 inches deep u have a 7/16 inch screw remove it then u can pull the first part of agitator, the second pc can be pulled out after but may not be that easy may have to pry it up
Mar 01, 2015 | Speed Queen AWS76NW Top Load Washer
How do i take agitator out of speed queen awn412 washer
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Aug 25, 2011 | Speed Queen AWN412 Top Load Washer
How to take out the agitator assembly in speed queen washing machine model awm693
That agtator fits and locks into place by a hub under it,by grabbing the outer edges of agitator and pulling straight up it should come off. Its not made to come off to easily and may need some muscle when pulling up.
Gene
Aug 17, 2011 | Speed Queen Washing Machines
How do I remove the agitator on my Speed Queen AA4211WE? There's no cap! It all appears to be one piece.
Jul 27, 2010 | Speed Queen AWS45NW Top Load Washer
How do i remove the agatator on a awm593w washer it is leaking grease
I used a tie down strap, I put one hook under the lip of the agatator on one side then the other hook 180 degrees opposite the first, grabbed both straps and lifted it right off the drive bell. Really easy. Good luck Don
Feb 01, 2010 | Speed Queen AWS44NW Top Load Washer
#awm693w,removing agitator to replace seals
Unscew the cap on the top of the agitator, then hit it back and forth with your hand and it will break loose. I just did it to mine today and it has not been of for twenty years.
Feb 02, 2009 | Speed Queen AWS75NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
196 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
