Question about Philips HI-296 Iron
Steam iron trips the main fuse
My iron works for an hour or so and then it trips the circuit. This happen regularly. If it's taking lot of power should it not trip the fuse straight away rather than taking an hour or so?
  • 125 Answers
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Posted on Sep 07, 2009
  • 700 Answers
If you are talking about the electrical circuit. It might be the reason is;
Maybe somebody use the same electrical circuit same where your iron is plug with enough load to trip the protection circuit.
Just a thought.
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
I have a Bosch b52l iron, when i turn on the steam button, it cuts off the power, what could it be
It could be the iron itself (it may have a short circuit in it) and the circuit breaker trips when the steam switch is turned on.
Option 1)
Another option is that the entire circuit that that circuit breaker is controlling is overloaded. What other outlets / applicances / lights are disabled when that circuit breaker trips? You may have to iron only when those other applicances on that circuit are not being used.
Option 2a) Your outlet may be damaged and causing your circuit breaker to trip when the high current STEAM setting is set.
- OR -
Option 2b) the circuit breaker is damaged and is tripping too easily. Only replace with a similarly sized circuit breaker (15 amp lis likely but is says right on the breaker).
Try the solutions in that order.
-Mark
Please rate me..
May 07, 2011 | Bosch Irons
Our philips iron keeps tripping our fuse box - this is the second model (but different model) that has done it - is there any advice you have as to why this keeps happening?
Your circuit is bring overloaded by the iron.Irons use lots of energy They usually use more than half the capacity of most electric circuits.Try it on another circuit or unplug some other heavy energy user on the circuit.Better yet have an electrician have a look on the circuit.
Feb 13, 2011 | Philips Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
Rowenta iron
Dropping any iron is the kiss of death... dont use it again, especially on the steam setting.. you could electrocute yourself..
Dispose of it safely and get a new one. You wont make that mistake again in a hurry... I didnt!
:o)
Aug 03, 2008 | Rowenta DZ1700 Iron
Philips HI-296 Iron Logo
1,158 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
