Question about Toshiba Satellite 1905-S301 Notebook
Power failure when i press power button it doesn'tt happen any thing
    Novelist:
    Champion:
  • 226 Answers
When you press the power button and nothing - I mean absolutely nothing - happens, and if your indicator panel is showing that it is plugged in, then it's a dead power button board. Period.
This is a common problem with the 1905 series.
Posted on Mar 11, 2010
    Problem Solver:
  • 6 Answers
    President:
  • 1,564 Answers
Unplug you laptop, remove your battery and the harddrive. Put them back in and it will come back to life. I had to do this several times last thursday for a customer. It works.
Posted on Sep 07, 2009
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Model Vizio SV420XVT1A will not power up. The Vizio logo is amber, nothing happens when you press the power button.
You will need to have the set diagnosed as there a number of things could cause this. But I would say you're looking at a power supply or main board problem. It is also possible that your key controller (side buttons) is defective. I take it the TV doesn't turn on with a remote either?
Sep 09, 2012 | Televison & Video
Is it possible to fix a non working PTT button on a RDV2020
The PTT button is one of the common failure parts. It is replaceable, but best done by an experienced repair center.
The following things can happen over time:
1) The internal PTT switch can wear out from frequent usage.
2) The user begins to press harder to get the PTT to work, bending the PTT switch further away from the external button the user is pressing.
3) Plastic diaphram, if any present, gets broken in half, and the external PTT switch doesn't work anymore.
Several companies offer flat rate repair on this style unit for around $85.
Best regards.
Aug 02, 2011 | Motorola Mobility RDV2020 RDX Series On...
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
Vivanco tt 716 remote instructions
I have a manual. What part do you need?
To retune the remote to your TV automatically press Power & Mute keys together. Then press TV key. You should have a blue light & a red light. Now press & hold the Power button until the blue light blinks twice & release. The remote will search for your code. If the TV turns off (sorry forgot to mention TV should be on first) quickly press the TV button again to store the code. Then press the Power button to check if the TV turns on again.
If you need the codes. Let me know
Sep 29, 2009 | Televison & Video
AUDI TT Dashboard problem with RPM
that is a common problem with all pre 06 audi tt dashboard clusters. You need to contact audi customer support in your country, (NOT tHE DEALERS) and tell them that the problem is a common fault and you want a free replacement. They will do it. They did it for me in 2009.
Jun 25, 2009 | 2005 Audi TT
2001 audi tt just stopped running while driving 55mph. wont turn back on now. power works. just wont turn over.
Timing belt might have broke. Same thing happened to mine. Going to cost ALOT of money to fix.
Apr 27, 2009 | 2004 Audi RS6
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Boot failure
does it beep at all?
take it into a dark room, can you see anything on the screen, even if it's very faint?
take battery off and plug in same thing?
Jan 04, 2008 | Toshiba Satellite A105-S4004 Notebook
TT 02 doesn't spin - Help!
i don't know if these are belt driven or not but i would check to see if the belt fell off, if motor driven then i would suspect a bad motor.
Dec 31, 2007 | Philips gemini TT-02 Turntable
Toshiba Satellite 1905-S301 Notebook Logo
301 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
